Mowing L39 lost clutch
/ L39 lost clutch #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
While my brother in-law was bush hogging lost clutch. Making passes pushed in the clutch to roll back a bit and lost clutch. No noise and everything else works. Intelapanel says the gst transmission goes thru the gears. No forward or backward travel. No pto. He had just changed UDT and filters with no issues.
/ L39 lost clutch #2
Sounds expensive!
/ L39 lost clutch #3
Start by checking the adjustment and looking to see if something is jammed underneath.
/ L39 lost clutch
Yeah$$$. Pto does work. Not real familiar with the GST. I have had clutches fail before but had some indication.
/ L39 lost clutch
He checked for sticks or debris in linkage. Checked wiring. Checked fuses. Loaded on trailer to take to Kubota dealer.
/ L39 lost clutch #6
did you find where the clutch fell??.. you wouldn't want the bush hog to contact that!..
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2008 MACK CHU613 (INOPERABLE) (A67714)
2008 MACK CHU613...
PORTA POTTY (A67714)
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
Unused HLA HD42 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused HLA HD42...
