Bent Axle?
/ Bent Axle? #21
Obvious by your pic that wheel was never properly welded.
You don't need to take the tractor to a shop unless it's a warranty fix. If not warranty you just need to buy a new wheel and transfer the tire.
/ Bent Axle?
Called the dealer. It's a warrant item. I'll bring him the tire and he'll remount the rubber on the new rim. Glad it was a simple fix. We need the tractor to spread stone on our driveway before company comes. The seat ripped too. I forgot to mention that.
/ Bent Axle? #23
Glad to hear it'll be taken care of.
Do you have a backhoe on this tractor?
/ Bent Axle?
U bet. I don't use it all that much but when I need it I'm happy to have it. Great tractor. I had no experience when I bought it. If I had to do it again I'd probably go up one size. Paid under 16k with delivery. Can't beat that
/ Bent Axle? #25
I'm trying to diagnose why the wheel failed. Hoping it's just a bad weld.
The backhoe would put a LOT of stress on the rear wheel. That probably sped up the failure.
/ Bent Axle? #26
Interesting. That is something I never heard discussed here with all the talk of Hoes. Always the integrity of the hookup and so forth.
/ Bent Axle? #27
A backhoe puts a lot of lateral stress on the rear wheels. Lateral stress is what caused this wheel to fail.
/ Bent Axle? #28
This is my left rear wheel, inside and out. No sign of width adjustment.
I've been pretty rough with it. All I have is slopes, so these have been at all different angles, loaded FEL or not, with and without BH or Tiller. Lots of uneven ground due to moles and rain runoff.
/ Bent Axle? #30
When you’re traveling on a side hill and cornering; or do you mean when using?
Because of the added "swinging" weight when carrying the hoe and because of the side drag on the tractor when using the hoe.
/ Bent Axle? #31
There's side load when driving around, especially on slopes. Using the outriggers to lift the rear wheels, even if only a bit helps when operating. I try to just take the weight off, not lift fully off the ground.
But we don't know if any of this caused the OP's situation, or if it was just a bad weld.
/ Bent Axle? #32
I think it was a bad weld that showed up when loaded with a BH.
/ Bent Axle?
Took the tire off today and there are two bad welds on the hub part that is inside the rim. The part is on back order and I'm having a hard time finding out when it will be in stock. Called LS and they were suppose to call me back but no luck. The dealer can fix mine for 125.00 and I'll have a backup when the other one comes in. Just a real pain in the arse. I'm in the middle of putting in a patio, moving dirt, installing a pump and installing a driveway. The tractor picked a bad time to fail. Pavers are going in Next week so I may have to bit the bullet and get it fixed at the dealer. I could take it to a welder locally but not sure if they can weld with the tire on and not too many welders have tire machines.
/ Bent Axle? #34
You don't use a tire machine to remove a rear tire on a tractor!
SR
/ Bent Axle? #35
I'd expect your Dealer to loan you a tire and wheel until yours came in.
/ Bent Axle? #36
$125 spare sounds decent to me.
/ Bent Axle? #37
So sure to be the cause, and why replacements are scarce if it's a vendor quality issue. ('legendary lemon', recall, etc)
I don't think there's a tractor so 'small' that this isn't a bargain. :)
Because I aspire to be like SR and a few other members I'd consider jacking the wheel, truing and tacking it, and taking it to a welder that IMO should only need to ground his - lead ok (some paint removal?) vs remove the tire to fix/replace the weak OEM welds.
/ Bent Axle?
It's not the money. Not that thrilled driving on a repaired rim that is cracked and has cracked welds.
/ Bent Axle? #39
A good welding shop will make it stronger than a new one.....but I understand some folks just don't like repaired things on their tractors, they just want it like new again.
SR
12in. Tooth Excavator Bucket (A64194)
12in. Tooth...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2016 DODGE RAM 1500 4x4 CREW CAB PICKUP TRUCK (A59912)
2016 DODGE RAM...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
