Hydraulic leak at lower lift arm
   / Hydraulic leak at lower lift arm #1
loganhorse
Reynolds station ky
John deere 2440
What the lower lift arm attaches, I have a pretty good leak. Is this a easy seal fix or something more?
2440.
   / Hydraulic leak at lower lift arm #2
Send a pic or two so we have a better "picture" what is happening.. tks
Loader model # will help too.
   / Hydraulic leak at lower lift arm #4
There is a serial number break at 025300 for the lift cylinders.. are you above or below?
Can get all the part numbers off of jdparts online.
John Deere Parts Catalog
Was referring to the rear lower lift arm sorry guys.
Pictures. Message_1590350420915.jpgMessage_1590350367678.jpgMessage_1590350445336.jpg
   / Hydraulic leak at lower lift arm #7
L/D control shaft seals are leaking. If this is the case the seals are easy to replace. One needs to heat the larger seal in warm water or oil. Put L/D lever under seat in D before removing shaft also drain hyd oil. Be sure to install shims to remove any side to side motion from shaft. Side to side motion of shaft prematurely wears out the seals.
I will check that out. I don't recall a lever under the seat but I'll double check when I get a chance.
   / Hydraulic leak at lower lift arm #9
If draining, may as well clean the sump screen.
I have done the seal replacement without draining, just slide the shaft in enough to access the seals. You will lose some oil, have drain pan under the seal.
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
KOMATSU PC400LC-7L EXCAVATOR (A51242)
KOMATSU PC400LC-7L...
VENTRAC 4500Z ARTICULATING TRACTOR (A51242)
VENTRAC 4500Z...
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
CATERPILLAR 299D3 SKID STEER (A51242)
CATERPILLAR 299D3...
2023 JOHN DEERE 30P TIER EXCAVATOR (A51242)
2023 JOHN DEERE...
