Hydraulic leak at lower lift arm
   / Hydraulic leak at lower lift arm #1
loganhorse
Reynolds station ky
John deere 2440
What the lower lift arm attaches, I have a pretty good leak. Is this a easy seal fix or something more?
2440.
   / Hydraulic leak at lower lift arm #2
Send a pic or two so we have a better "picture" what is happening.. tks
Loader model # will help too.
   / Hydraulic leak at lower lift arm #4
There is a serial number break at 025300 for the lift cylinders.. are you above or below?
Can get all the part numbers off of jdparts online.
John Deere Parts Catalog
Was referring to the rear lower lift arm sorry guys.
Pictures. Message_1590350420915.jpgMessage_1590350367678.jpgMessage_1590350445336.jpg
   / Hydraulic leak at lower lift arm #7
L/D control shaft seals are leaking. If this is the case the seals are easy to replace. One needs to heat the larger seal in warm water or oil. Put L/D lever under seat in D before removing shaft also drain hyd oil. Be sure to install shims to remove any side to side motion from shaft. Side to side motion of shaft prematurely wears out the seals.
I will check that out. I don't recall a lever under the seat but I'll double check when I get a chance.
   / Hydraulic leak at lower lift arm #9
If draining, may as well clean the sump screen.
I have done the seal replacement without draining, just slide the shaft in enough to access the seals. You will lose some oil, have drain pan under the seal.
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2020 Kia Sportage SUV (A50324)
2020 Kia Sportage...
