laurencen
- Joined
- Feb 19, 2007
- Messages
- 1,204
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
figured I would start a new thread for this issue, the Toolcat is now 4 weeks old, in general I am happy with it but the top speed really bugs the **** out of me, max engine rpm is 2600, it easily makes this and the max speed in low range is 8.5 mph at 2600 rpm, this it does no issue, in high range it reaches 13 to 13.5 mph at full throttle but then it drops rpm to 2350, if it could reach the 2600 the speed would easily be 17 to 18 mph but no can do
had the service out 3 times now, they have installed older software and have no idea other than its not allowing full rpm range when it gets to 13.5 mph and appears to be governing motor rpm to this speed
they contacted Bobcat who basically says some reach full speed, some go faster and some slower but have no fix, my main reason for having a machine was to take advantage of the high speed I enjoyed on the 2005 model, as I also said to them had my Corvette manual states it will do 200 mph plus and if it was only doing 150 I would return it, then I asked when are they sending a replacement out, for close to 80K with taxes it should get to published speed
and so I wait
and so I wait
