Plasma Cutter recommendations.
/ Plasma Cutter recommendations. #11
I don’t own a Hypertherm but it would be my first choice.
/ Plasma Cutter recommendations. #12
As primarily an observer a Hypertherm would be MY first choice but my wallet would go for Everlast.
/ Plasma Cutter recommendations. #13
I've done a bit of research and the following questions come to mind:
What is "Gouging"? Is that like digging some metal out without going all the way thru?
Most videos I see show plasma cutters starting at the edge of a piece of steel. Is it possible to start in the middle? Is that what is meant by "Piercing ability"?
Yes gouging is like carving. Handy method to remove welds in trying to disassemble without losing too much of the structure.
Piercing is just that... A method where you start the cut other than on an edge.
/ Plasma Cutter recommendations. #14
Hypertherm 45! I started with a Northern Tool (forgot who the manufacturer was) plasma torch, sold it and bought the best. I've had it for three or four years and still 100% satisfied.
/ Plasma Cutter recommendations. #15
I think it's only fair to include price on any suggestions to someone new.
I have a Miller 625 Extreme. I paid somewhere around $1250 for it. It will cut up to 1/2". Will cut 1/4" and thinner very well. Well supported brand.
/ Plasma Cutter recommendations. #16
No offense, but why would a company like MILLER, go with such childish/trending names? As ridiculous as the NASCAR stickers on my LINCOLN MIG!
I talked with a guy that fixes all makes of welder and cutters. Says the quality is just going down hill. Electronics instead of heavy transformers. Maybe it's the same trend as small tractors. It's gone to a consumer , non industrial/tradesman market.
/ Plasma Cutter recommendations. #17
I've had the Hypertherm 45 for some years now. Works fine. I wanted a no-excuses solution where I would know any shortcomings were my problem not the machine.
/ Plasma Cutter recommendations. #18
I have a thermal dynamic cut master 52. It was worth the extra $$ over a 42 for the piece of mind that I will be somewhat future proof. I can get consumables close by at the local tool store on the weekends or one of several welding supply houses. I looked at theEverlast products but any warranty work would require shipping the unit across Canada. One warranty repair would be more $$ than the cost savings. Cam
/ Plasma Cutter recommendations. #19
I think that many of the plasma power supplies are good. The weak link is always the torches. Most are copies of 1980's torches which is very old technology. One of my plasma's was sent to me by a top of the line manufacturer in China called WTL. The power supply is top notch and it was built to spec with the Hypertherm 45XP. You pick metal thickness and it sets amps for you. Has built in automation interface and many other things I won't get into just now. So what is the weak link? It uses an Italian torch called Tec-Mo. Actually it offers 2 torch options for hand cutting. One uses cheap Trafimet parts and the other uses Hypertherm 45 after market parts. They sent me both torches which are constructed poorly. What I noticed was the machine had at least 20 amps more power using the Hypertherm designed torch components. So when you buy a Hypertherm or Thermal Dynamics you get to pay a little more but you get state of the art torches and consumables. 99% of the off brand plasma systems are using 35 year old parts. They are inexpensive though. For some, HF welders are fine and cheap plasma cutters are too. Just get the best one you can sneak into the budget.
/ Plasma Cutter recommendations. #20
..... 99% of the off brand plasma systems are using 35 year old parts. They are inexpensive though. For some, HF welders are fine and cheap plasma cutters are too. Just get the best one you can sneak into the budget.
Bingo! I always try to buy commercial quality stuff - much cheaper in the long run.
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
New/Unused Electric Golf Cart (A61166)
New/Unused...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
2011 Caterpillar 304DCR (A60462)
2011 Caterpillar...
