Soil Screener
/ Soil Screener #1
TractorGuy
Elite Member
N. FL
John Deere 4410, John Deere 4120, Kubota LX3310 cab, John Deere F725 Front Mount Mower, Swisher 60" pull behind mower. John Deere 4310 CUT (sold), Ford New Holland 575E Cab Backhoe (sold).
I'm about to embark on building a soil screener. I've looked at several designs on You Tube and decided I am going with a stationery design with a fairly steep angle. Most of the models I've seen work but a couple stood out as the simplest and those worked as good as the vibratory models.
I spent a little over $250 on the metal. Had to pick and choose in the rack because he was sold down on stock and the truck wasn't coming until tomorrow. I didn't want to go back to town tomorrow so I ended up with some 1-1/4" 11 ga square tube for the perimeter of the frame with 3 sections of 1" 11ga square tube for the 3 extra screen supports. Going to use regular flat expanded metal for the screening surface. I bought two sheets of that so the area will be about 8' by 8'. I bought some 2"x2"x1/4" angle to use for the skids and upright supports. I may make it so the angle is adjustable but gonna start around 45*. It's gonna be heavy. Will post pics and give a review after I have it assembled and tested.
My soil is clay/sand mix and I have piles of dirt with wood debris in it. I've been just spreading it out and hand raking the trash out.
/ Soil Screener #2
Instead of using sheets of expanded metal I would check with any rock crushing plants in your area. Used screens are always cheap and plentiful and will last forever for your application.
/ Soil Screener
Too late for that. Metal is bought and on the trailer.
That woven wire stuff looks very heavy duty but I have a feeling my wood debris would stick in it too bad. I am hoping the flat expanded metal will allow the unwanted stuff to slide down better but we'll see.
I think the woven wire would work better for rocks but would probably require vibration to work effectively.
Here is one built from wood and expanded metal that seems to work okay.
I haven't found many that are screening wood debris. Most are just screening rocks which would be easier to screen IMO.
/ Soil Screener #4
If you are screening clean dry sand, that video is good during the last few minutes.
A complete waste of time if you live in the north east.
Vegetative material does not just separate out. At the angle shown in the video, over half of the desired screened material would not pass the screen.
I use an expanded metal screen for active compost and aged forest litter piles. 45 degrees and about 3 passes does the job. Got to love the FEL ;-)
The screen still takes manual raking to clear the debris.
/ Soil Screener #5
I need one of these. I live in hte north east, and have a lot of rocks. I have no topsoil, only clay. a stationary screen would be useless. I need something that moves. I have about 50-60 yards of soil that needs screened. I have a TLB and a bobcat without high speed hydraulics.
/ Soil Screener
Got it put together. First test looks promising. I welded a couple of cut up chain hooks to the underside to move it with. I carried it real slow but it seemed stable enough during transport to the back of the property.
Only dumped 3 buckets through it before a storm threatened so I high tailed it back to the house. I forgot to pick it up and clear the screen before taking the photo but I can rock it straight up and get most of the debris to fall off. I imagine I will have to pick up the debris side and dump it through again but a good amount of dirt fell on the clean side.
/ Soil Screener #9
Not sure how I missed this. I was wondering how well expanded steel mesh would work. I've already got one full sheet laying around. For the price of some decent angle iron, (what did you use? 1/8"? 1/4"? thick?) but I'd need to make mine at less of an angle, maybe two stage, big screen on top of finer screen, and vibrating. I've got lots of stuff to sift through, I'm tired of all the raking...
/ Soil Screener #10
Shaeff, check the link I posted (post#6) - might be more what you're looking for... Steve
/ Soil Screener #11
If you had two tractors at your disposal, I would put fork pockets on the screen and containment walls on three sides. Make a way to arrest the screen on the forks, and you could manipulate the load of soil a bit. Rock it back and forth a bit. Then dump the garbage off to one side.
/ Soil Screener #12
Be certain to take frequent breaks. Apparently too much screen time isn’t good for you.
/ Soil Screener #13
That's almost exactly the idea in my head, thanks Steve! I've already got many of the parts needed to build it, too.
/ Soil Screener #14
Sounds like a win-win; first win = me being able to remember I'd bookmarked it :rolleyes:, second win = you already having most of what you need :thumbsup: ... Steve
/ Soil Screener #15
You bet! I'm pretty excited about this project. I just need to find the time to build it. Maybe if I sent the wife away on a vacation LOL!
/ Soil Screener #16
It looks like it screens real well. But how do you get all the screened material out when the screen goes all the way to the ground and have a pile of big stuff at the lower end? You should at least put it up on something so the bucket has room to scoop the good stuff up. You could also push the big stuff 90* and get almost all of it if the containment wall is high enough.
/ Soil Screener
If I put it up any higher I probably couldn't get the bucket over the top to dump. The idea behind the design is to have a long sharp angle surface rather than have to build a vibrating mechanism.
These are not very good pictures since I took screen shots from the end of the video but it shows how much I scooped out from under the screen and the second photo shows where I piled the sifted soil. I have two hooks welded to the underside that I use to pick it up with the loader for transport and I can easily move it when I need to sort the dirty side.
/ Soil Screener
I stuck a cheap dash camera under the canopy today and screened a little wet soil. This gives a better idea of how i clear and move the screen with the hooks I welded to the back supports. Wet stuff doesn't screen that well.
TIRE RACK WITH TIRES (A67714)
TIRE RACK WITH...
2003 30ft Rinker Captiva Boat w 2017 30ft Tri-Axle HMDE Boat Trailer (A66738)
2003 30ft Rinker...
CAT 930 GP Bucket (A68134)
CAT 930 GP Bucket...
MAXEY PORTAPOTTY VAC TRAILER (A67714)
MAXEY PORTAPOTTY...
2008 THE MACHINE CO. THAWZALL H250 HEATER (INOPERABLE) (A68842)
2008 THE MACHINE...
500 GAL WATER TANK (A68842)
500 GAL WATER TANK...
