Looking for backhoe attachment recommendations
/ Looking for backhoe attachment recommendations #1
johnsville, ca
Kubota L4701
Please forgive my ignorance here. I have the kubota L4701 & am looking to buy a backhoe...kubota's bh92 is around $10k, which is a lot more than i want to pay. I came across woodmax which is selling a comparable backhoe for $5k. Whats with the massive prize difference? Im going to use the backhoe to dig fence post holes, 100's of yards of water line, footers etc. The soil is fairly rocky but soft. If anyone can share their knowledge i would appreciate it.
Thanks
/ Looking for backhoe attachment recommendations #2
The correct subframe is probably 3 k alone I'm not shure but a 92 is a 8" and anything around 5 k is probably a 5 or 6 footer. Don't mount a hoe without a subframe !!!:drink:
/ Looking for backhoe attachment recommendations #4
... Don't mount a hoe without a subframe !!!
Even if your soil is not rocky, don't mount a hoe without a subframe. There are many posts on this forum about broken tractors because it wasn't mounted with a subframe.
Thanks for the advice on the subframe. What do you guys recommend for the subframe and backhoe? Should i try to buy used? There are several brands of backhoe, some twice as expensive as the others and both claim the same capability as far as digging depth, digging pressure, etc.
/ Looking for backhoe attachment recommendations #6
Besides the subframe, the Woodmaxx is made in China. Which is fine if it's speced and QCed properly. Woodmaxx has a lot of experience doing that. The valve stack may not be as good as Kubota valves (they're known to make good valves). That will make a difference in how easy the BH is to operate. The subframe is specific to the tractor and the BH. Woods used to make some BHs with Kubota subframes but I don't know if they still do or if they did one for the MX series.
Check dealers for a used BH. I got a lightly used one from my dealer. It was roughly 2/3 the new price.
/ Looking for backhoe attachment recommendations #7
You don't dig post holes with a BH. Too much to backfill. A Post Hole Digger is $500 or so usually.
Hundred of yards of trenches will take forever for the inexperienced. If you have a rental yard close enough, look at renting a trencher or other machine. Having a tractor mounted back hoe is fine for small jobs like planting or moving trees. Some people on here that have them have done foundations and footing or bigger jobs, but they've had more experience than I do.
/ Looking for backhoe attachment recommendations #8
You could pick up a used BH 92 for 3-4 k the hard part is finding one close to you at the right time. Usually after you buy a new one a used one comes up.:D:drink:
/ Looking for backhoe attachment recommendations #9
You get what you pay for.
Id put that 10K towards an older used full sized construction backhoe and consider yourself lucky you didnt abuse the tractor. If you are tired of your tractor and want an excuse to give the wife for buying a new one, buy the cheap BH attachment.
/ Looking for backhoe attachment recommendations #10
Totally agree with waiting till you find something cheaper. They will come up. In the meantime if you have a job that needs to be done right now rent a mini-x. I waited and found a hoe (Different brand then my tractor - I modified the subframe/made brackets for approx $100 in steel plus my time) and that cost me half as much as a new hoe.
I also totally agree that while it's a great tool to have (It's on my tractor a surprising amount of time) it's no where near as effective as something like a mini-x or a "real" backhoe. But for the odd jobs I'm doing around my property it's awesome. Including post holes btw! I'm currently putting up a fence which is primarily running thru a forest - tons of roots and stones - I originally thought of renting a post hole digger, but decided to give the hoe a chance - glad I didn't rent anything, the hoe makes short work of roots that would have been a royal pain in the butt. Ya, it's a little bit more back-filling but for 30 plus holes I'm not bothered.
A strong subframe/solid tractor attachment bracket/points are the most important thing really. That is what will protect your tractor from the forces of the hoe. The hoe whether cheap or expensive will exert the same force on the tractor so it's how it's attached and ultimately how you use it that will dictate whether the tractor gets abused or not. Personally while I'm happy to hook the hoe up at any time, if a job came up that was going to require days of hard work I'd go rent a mini-x/backhoe - they will at that point be much more efficient and quicker. The rental will be money well spent.
E.
/ Looking for backhoe attachment recommendations #11
As others have said, a sub-frame is most important. I like the convenience of being able to have the BH attachment available anytime I need to dig up a leaky waterline, plant a tree, or dig up a stump, etc. My nearest rental place is an hour one way away from me and half the time their mini-x is out which prompted me to get my BH attachment. Personally, if I was to use a cab tractor with the BH, I wouldn't bother owning the attachment and I would go with a separate machine. If you are going to do any trenching, You need to be able to reach the loader control from the BH seat so you can raise and lower the loader when you need to move. That way you can push the tractor along while you trench with the hoe. Otherwise you need to get on and off every time you need to move or have an additional person drive for you. My BH attachment is a Woods and has given me good service by the way.
/ Looking for backhoe attachment recommendations #12
I looked at getting a Woods BH for my JD tractor, but found that they were about $2k more than what JD wanted for theirs.
My BH has a reach of about 8', but I find that when I'm trenching, I move about 4 feet at a time. Lots of climbing up and down to move.
/ Looking for backhoe attachment recommendations #13
When trenching, most of the time I just use the backhoe to shove the tractor ahead and continue digging.
/ Looking for backhoe attachment recommendations #14
Thanks
Check out Ansung. They are like LS, they are the manufacturer of other brands products.
Tafe 45DI (A60462)
Tafe 45DI (A60462)
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lift (A61568)
2010 Ari Hetra...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
