MIg Gun Trigger Guard
/ MIg Gun Trigger Guard #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
Was watching welding a video and caught a glance (long enough to realize what it was) at mig gun the has "trigger guard".... Since I always seem to lay gun down in a way the trigger get depressed and I waste wire (to lazy to drag it back on spool), anybody have a home grown or purchases solution....
I am open to ideas!....
Dale
/ MIg Gun Trigger Guard #2
Guards are often a cure worse than the disease.
Wonder about an actual hook so if you hang it over something you don't rely on the trigger as "the hook".
/ MIg Gun Trigger Guard #4
I can’t think of an effective guard. The best I can do is be cognitive of how and where I place the gun when the the welder is energized.
Storage spots for gun on cart...
Portable magnetic base. The vertical socket is for the plasma cutter torch...
Most times I hang it like this as it is quick, easy and relatively foolproof.
/ MIg Gun Trigger Guard #5
Only thing I've seen with a guard is Plasma. Likely due to the accidental ear pierce when you do an air check. ?
/ MIg Gun Trigger Guard #6
I like that mag base multi holder... looks 'not homemade', but I'd sure copy it for my own use in a heartbeat!
/ MIg Gun Trigger Guard #8
Everywhere I weld I stick a scrap piece of pipe welded on to table legs welding cart ,gas cart ,anything .6-8 " pipe welded at a 45 perfect holster and it's free':cool2::drink:
Ummm... Do not have welding table (yet?), that is another dream out there a bit... So magnetics are probably out... Probably have to go with pipe/tubing sleeve on welding cart, and get into habit of "holstering" gun at cart....
Dale
/ MIg Gun Trigger Guard #10
I recently decided to make a stand for a vice I have had too long, without having built the bench it was supposed to be mounted on.
A simple build, and I had all the material on hand.
But then, I realized I was most of the way to finally having a welding table. :thumbsup:
So, another simple build, with materials on hand.
And, that led to the mig gun holder, which is a ring welded to the welding table.
Bonus, since the welding table is held by the vice, it is height adjustable. :cool2:
Now, I can't think of a reason why I didn't do this sooner.
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2016 GMC Sierra 1500 Crew Cab Pickup Truck (A59230)
2016 GMC Sierra...
2011 Ford Crown Victoria Sedan (A59231)
2011 Ford Crown...
TAG 32in. Bucket Excavator Attachment (A60352)
TAG 32in. Bucket...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A59230)
2008 Ford F-550...
