MIg Gun Trigger Guard
/ MIg Gun Trigger Guard #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
Was watching welding a video and caught a glance (long enough to realize what it was) at mig gun the has "trigger guard".... Since I always seem to lay gun down in a way the trigger get depressed and I waste wire (to lazy to drag it back on spool), anybody have a home grown or purchases solution....
I am open to ideas!....
Dale
/ MIg Gun Trigger Guard #2
Guards are often a cure worse than the disease.
Wonder about an actual hook so if you hang it over something you don't rely on the trigger as "the hook".
/ MIg Gun Trigger Guard #4
I can’t think of an effective guard. The best I can do is be cognitive of how and where I place the gun when the the welder is energized.
Storage spots for gun on cart...
Portable magnetic base. The vertical socket is for the plasma cutter torch...
Most times I hang it like this as it is quick, easy and relatively foolproof.
/ MIg Gun Trigger Guard #5
Only thing I've seen with a guard is Plasma. Likely due to the accidental ear pierce when you do an air check. ?
/ MIg Gun Trigger Guard #6
I like that mag base multi holder... looks 'not homemade', but I'd sure copy it for my own use in a heartbeat!
/ MIg Gun Trigger Guard #8
Everywhere I weld I stick a scrap piece of pipe welded on to table legs welding cart ,gas cart ,anything .6-8 " pipe welded at a 45 perfect holster and it's free':cool2::drink:
Ummm... Do not have welding table (yet?), that is another dream out there a bit... So magnetics are probably out... Probably have to go with pipe/tubing sleeve on welding cart, and get into habit of "holstering" gun at cart....
Dale
/ MIg Gun Trigger Guard #10
I recently decided to make a stand for a vice I have had too long, without having built the bench it was supposed to be mounted on.
A simple build, and I had all the material on hand.
But then, I realized I was most of the way to finally having a welding table. :thumbsup:
So, another simple build, with materials on hand.
And, that led to the mig gun holder, which is a ring welded to the welding table.
Bonus, since the welding table is held by the vice, it is height adjustable. :cool2:
Now, I can't think of a reason why I didn't do this sooner.
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
Caterpillar 320 (A60462)
Caterpillar 320...
2018 ALLMAND MP40-8BI-PORTABLE DIESEL GENERATOR (A59823)
2018 ALLMAND...
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
