Must haves for New Tractor
/ Must haves for New Tractor #1
rushipa
Conroe, TX
Mahindra 1626 Shuttle
Just brought a Mahindra 1626 with backhoe... First time owning a tractor... Wondering what are the must-haves and and brand / type recommendations... so far my list is
1. Diesel Fuel Can (don稚 laugh)
2. Grease gun - leaning towards Dewalt battery operated
3. Grease - Lithium with Moly ?
4. 1/2 Torque wrench (again don稚 laugh)
5. Chains
What else ?
TIA for all the valuable input for experienced owners !
/ Must haves for New Tractor #3
Spinner knob for the steering wheel.
Congrats on the new machine! :thumbsup:
Thank You!
Hmmm... Had never heard of one before... now I see the usefulness...
/ Must haves for New Tractor #5
A SawHaul chainsaw carrier is a nice addition if you do much work with a chainsaw. Also most people like to get a set of pallet forks too. They are a pretty handy and versatile attachment for your tractor. You'll find yourself storing lots of things on pallets after you have a set of forks to move them around!
/ Must haves for New Tractor #6
Power steering. Pallet forks. I love my pallet forks.
Diesel fuel can? psh. I have 2 55gal diesel fuel drums. Don't pay road tax on your diesel fuel. Find a place that sells off-road diesel, get a trailer, get a couple of drums, and get an electric pump. 55gal drums are $10-15 on craigslist all day long. Cheaper than a 5gal fuel can. You can get a pump that will attach to the 2" drum bung hole for $100. More if you want features like gallon counters or automatic shutoff. I don't have either but the auto shutoff would be nice.
/ Must haves for New Tractor #7
rushipa
Just brought a Mahindra 1626 with backhoe... First time owning a tractor... Wondering what are the must-haves and and brand / type recommendations... so far my list is:
1. Diesel Fuel Can
I have steel and PVC fuel containers. I prefer PVC. Tuff Jug is the brand I like. With Tuff Jug design tractor filler opening bears some of the full fuel container weight.
Your fuel consumption will be 1/3 gallon per hour. Five gallons will last you 15 engine hours, which will be three, probably four days of home tractor operation. Buy FRESH diesel for only one month at a time. Almost empty tractor fuel tank before refilling. (Average residential tractor use is 60 engine hours per YEAR.)
tuff jug diesel container - Google Search
Overkill for just a tractor, but why not?
YES. Molly HP grease is the standard for Loader and Backhoe pins and a good general purpose grease. Molly grease is one increment "better" than plain lithium grease. You will likely use <one standard cartridge per year. I buy Walmart and TSC interchangeably.
VIDEO: How to replace grease in a grease gun - YouTube
5. Chains
Your tractor only weighs 2,400 pounds. Maybe 4,000 pounds with Loader and Backhoe. Tractors with 4-WD can tow about 75% of operating weight, so 3,000 pounds will be your max chain working load. 1/4" GRADE 70 chain will be ample. If you want to be over-engineered, then 5/16" GRADE 70 chain. GRADE 70 slip hook on one end, GRADE 70 grab hook on t'other end.
Walmart, Lowe's and Home Depot have bags of 20' GRADE 70 chain with grab hooks on both ends pretty cheap. Have store cut into 8' / 12' lengths in store. Pretty difficult to cut GRADE 70 at home. Take off one grab hook, replace with GRADE 70 slip hook for cinching up on logs.
VENDER: G7 Logging Chain 1 Feet with Choker Hook 5/16 Grade 7 WLL # 45 lbs | eBay
Rear/center drawbar with clevis mount chain grab hook. For towing loads with chain.
DRAWBARS: https://www.tractorbynet.com/forums...s-drawbars-illuminated.html?highlight=drawbar
What else ?
5/16" Bucket Chain Grab Hooks for lifting. 5/16" bucket hooks will hold 5/16" and 1/4" chain securely.
Home - BoltOnHooks LLC
Maybe a root-cutting hook as alternate to Backhoe bucket if you plan on removing tree stumps.
IMPLEMENTS: https://www.lsuagcenter.com/~/media...aa214276e14dacb/pub2917tractorimplements1.pdf
/ Must haves for New Tractor #9
Nice looking tractor. I agree with forks, I use mine all the time. Is the FEL a quick connect? If it is I’d get forks with the head ache rack. Will you leave the backhoe be left on all the time? If not you might look at a ballast box. I agree on the grease gun. For me it’s much easier with a battery powered gun to get a new cartridge started. I usually use an all purpose grease. I think the type isn’t that critical.
/ Must haves for New Tractor #10
5. Chains
What else ?
Here's a list I wrote up in another topic: https://www.tractorbynet.com/forums...sons/425021-things-i-didnt-consider-when.html
Some of it's slightly frivolous, some maybe not. Tools was a big thing for me, none of my tools were big enough for the tractor.
I like the American Eagle metal gas/diesel cans, sometimes they can be had on amazon for a good price (where "good" is relative, $37 or so).
I feel no need for a battery operated grease gun, but I did buy a Lock-N-Lube grease coupler and it makes things a lot easier and faster. LockNLube(R) Grease Coupler | LockNLube(R) - LOCKNLUBE
What you need will depend on where you're housing your tractor and attachments too, perhaps.
/ Must haves for New Tractor #11
Welcome to the forum, nice looking tractor, I have his little brother eMax 22. No laughing about any of your suggested items, the dedicated diesel fuel can is a must, yellow for diesel of course, everything else around here is gasoline powered, you don't want to take a chance on misfuelling. For people who use a lot of fuel, the 55 gallon drum would work, the fuel would likely go bad before I used it all.
Good call on the torque wrench, best to be precise.
Ballast box was suggested, I loaded the tires with methane, plus I bought a Titan weight bracket- receiver hitch, and bought eight 42 lb. suitcase weights. The receiver comes in really handy to tow my 12' flatbed trailer when clearing brush in my woods.
/ Must haves for New Tractor #12
Jeff9366 - great answers. One item - I have used 3 cartridges my first year at 88 hours. Kioti recommends greasing the loader every 10 hours and at even a few pumps per fitting that is a bunch. Add in a bushog and using that 4-5 times per year with u joints, tail wheel, etc, and a tiller, and I am considering a lube shuttle to make reloads easier and less messy. If I had a backhoe with those fittings as well then I think I might be at 4-5 cartridges a year.
General - I have recently read some disturbing commentary on safety of wheel spinners if you are ever involved in a rollover. With today’s power steering are they still worth it?
/ Must haves for New Tractor #13
If you plan to mow pasture there is nothing like a Rotary Cutter / Bush Hog.
Light duty - grass only - 450 pounds
Medium duty - grass and brush to 1-1/2" - 650 pounds
Heavy duty - brush to 2", occasional 2-1/2" - 1,000 pounds
Operator prudence is the most important safety function. Also true that heavier mowers have greater inertia therefore less effected by blade collisions.
Tractors are fairly stable with FEL removed. FEL weight is mostly above axle height, raising center-of-gravity for tractor.
Flail mowers are the alternative to rotary cutters.
/ Must haves for New Tractor #14
Nobody is laughing... Hah! BTW, nice tractor. Love the color. We all have to have fuel cans. It's called a can, but most of us use heavy PVC. Get Yellow for Diese and Red for gasoline. Be religious in keeping them separate duty In fact, get at least two 5 gallon fuel cans. I like the brand called No-Spill. They have the best caps I've seen. Look at them on Amazon. Yes, they are surprisingly expensive for good ones. Don't forget to get a heavy duty shallow rubber tub that both fuel cans will fit into. That keeps the diesel fuel from getting all over when you inevitably spill some or some leaks past the cap.
All the grease guns I know work fine. You will probably end up with several. Might as well get a traditional manual lever type too. They are cheap. Don't forget a 5 gallon pail to keep grease tubes and the grease gun in.
Your choice, but you aren't really dealing with enough weight-induced stress to need the moly. Moly is better for really high stress, but it is overkill for your size machine. And moly is nasty black and messy stuff. It's just not necessary for yours. For a smaller tractor I prefer a clear or green grease so that it wipes off easily and doesn't get all over everything. I use that most everywhere and particularly anywhere I might look at or rub against. My favorite is John Deere SD universal Polyurea green grease. about $4.50 a tube.
Neither you nor the machine will ever know if you use moly or not.
Now I confess that I do have one grease gun loaded with really nasty sticky moly grease. I use it in a couple of places on our big 100 hp 20,000 lb tractor where loads are high. Specifically I use it for the bottom swing pivots on the backhoe, and sometimes for the backhoe bucket when working in water. Never on the FEL, though. But you don't really need moly.
The kind with a pointer are way less expensive than the adjustable click type and just as accurate - if not more so. And that kind never goes out of adjustment. The 1/2" size is too limited. Get the 3/4" drive size. You can put a $5.00 adapter on it for 1/2" bolts and you will need the larger size for wheel nuts. Get some sockets & wrenches as you need them.
5. Chains
I see Jeff has written about chains. I have two short ten foot chains long 5/16" chains with grab hooks that I use a lot. You will definitely want to put some bolt-on chain hooks on the FEL loader bucket. That's the first thing we all do. Use high tension bolts
What else ?
The steering wheel spinner of course.. You'll see why when you use it.
I have an 8x10 heavy canvas tarp I find useful to cover the tractor operator seat when it stays outside.
Welcome,
rScotty
/ Must haves for New Tractor #15
So far with 4wd I've never needed chain. Have them on a 2wd-too lazy to remove them. You may need wheel spacers to give you the needed clearance to run chains.
If you make your own chains a load binder on the outside makes a good chain tensioner. Use a quick link over the handle and hair pin to keep it latched.
/ Must haves for New Tractor #16
Many years ago, we were always told to keep the fuel tank full. They were metal tanks than and we did not want the moisture in the tank or the rust that comes with it. I buy diesel (off road) 20 gal. at a time so it does not have time to collect water before I use it. Most new tanks are plastic and the filters take out the water.
/ Must haves for New Tractor #17
I was having a conversation with my dealer about keeping the tank full in winter. He said there's no reason to, and that doing so only increases the amount of fuel preservative I'll have to add. So apparently he's not worried about condensation, at least for my new tractor. News to me anyway, but I'm new to this whole new diesel thing.
/ Must haves for New Tractor #18
My wife gave me DeWalt battery operated grease gun for Christmas and it is GREAT! Not that greasing is hard, but the powered grease gun makes it easy. I grease all 3 tractors and whatever implements while they are warming up. The biggest downside, because I actually grease according to the recommendation now, I use more grease than before.
/ Must haves for New Tractor #19
How about spare linch pins and such, low pressure tire gauge (one that covers the pressure your tires run), paint marker, tools you can keep in the tractor toolbox and save a walk back to the barn, binder for all the manuals and a service record book. I'm sure I'll think of more are I post this too.
/ Must haves for New Tractor #20
Forks, extra pins, couple of good 12” adjustable wrenches to round off bolts like a good farmer would, box blade.
For your torque wrench, look at Tekton, very pleased with their stuff.
