GM I6 Diesel Impressions
/ GM I6 Diesel Impressions #21
I am a diesel nut. Will always own one.
But I have to tell you, the 5.3L GM gasser is such a good little engine.
I have one in a Loaded 08 Chevy Tahoe with 210,000 miles on it. Still pulls strong. Only thing I did was timing chain & guides at 180K which is considered sort of “ wear item “ in the owners manual.
I put a new oil pump in it while I was in there. ;)
Dirt cheap to fix, too.
Original motor and transmission :thumbsup:
/ GM I6 Diesel Impressions #22
I bought nothing but diesel pu's from 1982 to 2012.
With what the gas engines are doing today for power and torque, then take into account what the diesel option cost is, and the higher cost of owning a diesel, I'm all done with buying diesels in new pu's
My last two new pu's are gas, and I'm very happy with their performance and fuel cost per mile, I'm sticking with gas pu's...
SR
/ GM I6 Diesel Impressions #23
The only gas truck I'll buy is an ecoboost, because it drives like a diesel.
I don't like to have to rev the **** out of a motor at elevation. A diesel at elevation is effortless power...
/ GM I6 Diesel Impressions #24
Any supercharged or turbo will run better at elevation as it makes up for the thin air. Even the old non-turbo diesels were horrible up in the mountains.
/ GM I6 Diesel Impressions #25
I own 3 diesel trucks that are aging out, when and if I replace them it will be trucks with gas engines. Diesels are great at towing, but unless your constantly towing the extra cost of fuel and repairs doesn't justify their higher upfront cost and higher fuel price. Just ask the parts dept. the cost of 1 injector.
/ GM I6 Diesel Impressions #26
Yeah I just lost a #4 injector and it was $595 to replace.....:mad:
However, I tow so much, I’m still buying diesels.
I hate gas (the kind that you put in your car :laughing: )
/ GM I6 Diesel Impressions #27
I bought a new pickup in Feb this year. I test drove a Siverado with the 3.0 Duramax. I did like the way it drove, liked the sound of the diesel and that torque. But absolutely do not trust any Tier 4 diesel engine. Was open minded enough to look, but in the end decided there are just too many accounts of problems with Tier 4 diesels of all makes and sizes for me to sleep well at night.
Fuel costs between gas and diesel in my home state of PA also negate any advantage of increased fuel economy. Yesterday regular gas $1.85, diesel $2.99.
I do hope that in the future the engineers can get this together and the price of diesel falls more into line with gasoline. Until that time no Tier 4 diesel pickup for me.
/ GM I6 Diesel Impressions #28
The cost delta between gas and diesel is a moving target, right now in my area diesel is $0.34 more than gas. Typically, by mid-summer, diesel is less than gas and that continues until the home heating oil season begins.
I need a diesel to pull three of the four trailers I have. I buy new with a factory extended service contract that covers me for eight years (maximum I can get). After eight years, I get a new truck with an extended service contract. In 2015 I went with a RAM 3500 Cummins and the Mopar extended service contract. I've had both GM and Ford in the past, the Mopar extended service contract is the best one I've had to date. I also have the extended service lifetime on my 2013 1500 RAM. This is what works for me. I just hope in 2023 I can repeat this strategy.
/ GM I6 Diesel Impressions #29
Not trying to hijack this thread but my opinion on the gas or diesel topic.. If you are hooked to a heavy trailer all the time ...get the diesel. I have a 17 F450 V10 dump. Truck has miles of power and 10 very hungry mouths to feed. Avg is 6.3 mpg ..All this truck does is pull a 10K trailer or push snow. My 18 F350 diesel will get 15+ mpg doing the same. The dump truck has less than 7K miles on it in almost 3 years so I just don't use it enough to justify the 12K more for the diesel motor.
/ GM I6 Diesel Impressions #30
Yes, it mostly comes down to miles driven and weight of the trailer.That’s the reason why most all medium and heavy duty trucks are diesel.
Youll see some gas powered dump or box trucks here and there but they usually don’t tow much more than a 7 ton trailer.
I think gas engines have recently undergone improvements, like turbocharging to make them more appealing, but there’s no way I’m pulling 30,000lbs with a gas truck.
/ GM I6 Diesel Impressions #31
This thread is about the 1/2 ton Chev 3.0 inline 6 cylinder diesel, not heavy duty trucks towing heavy loads.
Absolutely the diesel rules in those heavy duty applications. 1/2 ton pickups much more debateable.
/ GM I6 Diesel Impressions #32
We know that, but the original post by the author of the thread discussed diesels, too. That generally opens the discussion up to anything related to what he discussed in the first post, wouldnt it?
/ GM I6 Diesel Impressions #33
Not my thread, but IMHO, the OP was specifically talking about the Chev 1/2 ton 3.0 diesel. To my way of thinking that would rule out the heavy duty stuff.
In no way am I trying to be argumentative. The only similarity between the 3.0 Duramax 1500 and a 3500 6.6 Duramax is that they are both diesel of course and GM. Completely different horses.
/ GM I6 Diesel Impressions #34
All good. These threads wander around. Even the OPs will take threads in other directions.
/ GM I6 Diesel Impressions #35
This particular engine in the Chevy/GMC half-tons is pretty down on towing capability, and it's due to thermal management according to a GM engineer I talked to. In order to get the good efficiency, they were very careful with thermal loads and under hood heat management. There are some very specific decisions they made with under hood arrangement, insulation, foil shielding, etc. He said they planned to revisit that to increase the tow rating, and that is already underway from the sounds of it. It will likely come with a reduction in the fuel efficiency. Be curious to see if this is done across the board, or as part of an optional diesel max-tow package (as I expect).
I found that in the GMC lineup, the 5.3L has the best ratings for towing and cargo capacity. The 6.2L loses some of both because it is so much heavier (specs as 440# heavier curb weight, which seems hard to believe). The diesel is better than the 6.2L for cargo capacity, but 100# worse for tow rating.
/ GM I6 Diesel Impressions #36
It’s funny how some seemingly unimportant parameter can be exceeded and render lower towing ratings. Wanted to buy a Jeep Gladiator Rubicon Diesel next year and preliminary towing ratings are slightly lower than gas. Now I know few people will tow heavy trailer with a Jeep Gladiator, but it still seemed strange.
I dug a little on the topic and found out the engine compartment couldn’t allow the Diesel engine to cool off enough to take advantage of its superior torque for towing, so they down rated its towing specs.
It is quite revealing to see how a 3L DIESEL has same specs as a gas engine double its displacement.
Diesel engines rock!
Finally refilled after the trip when I brought my tractor back. 542 total miles on the trip meter this time, 22.26 gallons, average fuel economy of 24.4mpg. About 125 miles with 7k load, 145 miles with 2k empty trailer, and the rest with just me commuting. I tried watching the onboard meters as I went, but they aren't perfectly accurate. My best guess was around 25mpg with the empty trailer, and about 16mpg towing 7k - both at interstate speed limits. The rest was work commuting at speeds under 65mpg, which it likes better than 65+. As an FYI, the "best 50" mpg recorded on the dash meters so far is 33.3. Just under 3k miles on it now and I still love it. Tranny feels a little lurchy at takeoffs, but I'm sure I'll get to the point where I don't even notice in a while. during the summer months I do most of my commuting in an older car, so I won't get as many miles to evaluate it again until next winter.
Oh yeah, diesel down to $1.999 within 10 miles of my house. Cumulative economy after 6 tanks: 2860.7 miles at 27.7mpg
/ GM I6 Diesel Impressions #38
Those are some impressive fuel mileage numbers for a full size truck!
/ GM I6 Diesel Impressions #39
Impressive!! Great to see another viable diesel alternative.
Newer diesels have increased efficiency. My ‘20 11,000lb Ram Cummins with a 4.89 rear gets same fuel economy as my 7,500lb 08 F-350 Powerstroke reg cab with 4.10 rear.
/ GM I6 Diesel Impressions #40
Chevy might have to run two radiators like ford did in the 6.7 to get the duty cycle of thermal loads under control. I saw the numbers somewhere that showed two smaller radiators did a better job cooling than one big radiator. The reasoning was most of the heat was removed in the upper half of the radiator which made big radiators have a decreasing return on cooling because there was not enough surface area on the top half to carry the heat away. Another simple fix was to slow the flow through the radiator to maximize the heat transfer through the radiator. The problem was the high flow was needed in the engine block, but low flow in the radiator. They could not differentiate the two different flow rates with one water pump.
It always amazes me that diesels make no heat idling, but put a load on them and the heat gets hot quick. I think it must be due to the higher BTU content in diesel...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A60736)
2020 TROXELL...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
1996 GREAT DANE TRAILER 48X96 SPREAD AXLE FLATBED (A60736)
1996 GREAT DANE...
2022 Mac Trailer T/A Walking Floor Trailer (A61568)
2022 Mac Trailer...
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
