would you use this bush hog?
   / would you use this bush hog? #72
I would take the shear bolt out and make sure the yoke is not rusted to the shaft......
I would also make sure that the circlip on the end of the shaft is still there, that is all that keeps the shaft in place and makes it so it can't flop around when you break the shear bolt.
Aaron Z
   / would you use this bush hog? #73
Would you not have extra shear bolts?
Oh yeah, sure I would once I establish its a working machine. Why go out to the hardware store and buy extra shear bolts before you spin the dang little beast up first to see if it runs??
I just mean all this preparation, walking the property, preparing for the worst.., etc
Better call the building and zoning inspectors and make sure theyre ok with it. :rolleyes::laughing:
Maybe see if you need a permit? :laughing:
   / would you use this bush hog? #74
Gotcha
I will rely on the OP to further investigate the condition of the cutter before he invests in it.
If he doesn’t know to do that, the best way to learn is by doing.
Aaron Z
great tip. i just ordered some shear bolts and an external snap ring assortment.
ok. the bush hog turns over by hand. i will pull it in the shop once i get the tractor, get it safely turned over and inspect the blades and stump jumper. remove the shear bolt, ensure the shaft is not rusted shut, replace shear bolt and add snap ring.
only thing left is the gearbox lube. on something like this, is it worth trying gear oil or should i assume seal is shot and go straight to corn head grease?
also is it worth the effort and expense to weld something like this to the front?
King Kutter Front Chain Guard, 5 ft
   / would you use this bush hog? #76
Look it might still have gear oil in it then mow a little and recheck.....
   / would you use this bush hog? #77
Before everyone gets all worked up about walking the property, I don't do that if I know the property and I am confident there are no "surprises" lurking about. I do walk the grounds if I think there might be surprises.
For example, I walked through this before I just started plunging through 8' tall brush (which kept me from hitting a few stumps).
   / would you use this bush hog? #78
Gotcha
Yeah ok, I hear ya....
Just seems like theres some good solid steps to take when buying a simple brush mower (I actually thought he had bought it by now) and theres the “ overkill “ on the analysis.
I mean what’s next? Run the serial number through a local dealer to see if it has any recall campaigns??
Ya know that’s actually not a bad idea.....:D
   / would you use this bush hog? #79
I used to do that, too. Then I realized Lyme Disease is pretty bad. Now instead of walking the property if its a new customer, I mow it very slowly. Usually I will hang my 8 foot bucket on the front of the loader, curl it all the way back and let it hang about 8 inches off the ground with the loader in soft ride mode.
If I hit something, the loader will ride up over it, and I can stop to investigate.
I just cut this place for the first time after customer let it go 2 years. I hit one stump and an area of rocks. Loader found them in the overgrowth real easy. No big deal.
   / would you use this bush hog? #80
The OP doesn't have to buy the mower. It was left on his property - FREE - FREE - FREE!
2021 Ford F-250 (A55973)
2021 Ford F-250...
2021 Ford F-250...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2017 Ford F-550 Chipper Truck (A56858)
2017 Ford F-550...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
