would you use this bush hog?
   / would you use this bush hog? #61
I would take the shear bolt out and make sure the yoke is not rusted to the shaft......
will do. the bolt looks fairly new to me, suggesting the bush hog was in recent use. that is a good sign.
Be careful on those hills if the vegetation is high, never sure what lurks beneath to cause trouble.
will do. maybe i will drive over it without the bush hog first to see what i find.
   / would you use this bush hog? #64
And make note of the diameter, length and hardness of the bolt. Buy spares when you are at a place that sells them before you need to make a special trip while you want to be mowing.
   / would you use this bush hog? #65
I didn't see where anyone mentioned to make sure the blades swing freely on the stump jumper underneath. If they don't, it will shake the crap out of the tractor and not cut well.
   / would you use this bush hog? #66
I would walk the area the first time to look for obstacles.
   / would you use this bush hog? #68
Unless there's an old transmission or boulder laying around.
   / would you use this bush hog? #69
Paralysis by over analysis.
Is anyone like just check the obvious things, hook it up and run low speed, and once that’s cleared, just start mowing? :laughing:
i was kidding. i will walk it. no sense messing up good equipment, especially a brand new tractor.
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
66'' SKID STEER BUCKET (A56857)
66'' SKID STEER...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
2007 JLG 450AJ SERIES II SKYPOWER BOOM LIFT (A52709)
2007 JLG 450AJ...
