would you use this bush hog?
   / would you use this bush hog? #61
I would take the shear bolt out and make sure the yoke is not rusted to the shaft......
will do. the bolt looks fairly new to me, suggesting the bush hog was in recent use. that is a good sign.
Be careful on those hills if the vegetation is high, never sure what lurks beneath to cause trouble.
will do. maybe i will drive over it without the bush hog first to see what i find.
   / would you use this bush hog? #64
And make note of the diameter, length and hardness of the bolt. Buy spares when you are at a place that sells them before you need to make a special trip while you want to be mowing.
   / would you use this bush hog? #65
I didn't see where anyone mentioned to make sure the blades swing freely on the stump jumper underneath. If they don't, it will shake the crap out of the tractor and not cut well.
   / would you use this bush hog? #66
I would walk the area the first time to look for obstacles.
   / would you use this bush hog? #68
Unless there's an old transmission or boulder laying around.
   / would you use this bush hog? #69
Paralysis by over analysis.
Is anyone like just check the obvious things, hook it up and run low speed, and once that’s cleared, just start mowing? :laughing:
i was kidding. i will walk it. no sense messing up good equipment, especially a brand new tractor.
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A56435)
1995 Ford F-250...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2009 Dodge Ram 3500 Flatbed Truck with Liftgate (A55973)
2009 Dodge Ram...
