Kubota G1800
/ Kubota G1800 #1
Marcus177
Kubota RTV-X 900
Hi,
I have the same problem as listed on line. The alternator has 15 V across the terminals at idle. The instrument panel has the no electrical charge light on. The battery is not charging, but the battery does recharge with an external battery charger. Can you tell me where the regulator is? Is the rectifier in the regulator unit, or located somewhere else?.
Thanks. Mark.
/ Kubota G1800 #2
I think the voltage regulator is located behind the screen upper left side behind steering wheel if seated on tractor.
Go to the Kubota site or Coleman Equip and look at the parts breakdown to see a clearer picture of it.
22R
/ Kubota G1800
Hi,
Thanks. Mark.
The wiring diagram shows both the wires from the fan dynamo (alternator) going in to the regulator. I would expect the inverter to be within the regulator unit.The wiring diagram shows a separate unit called "change AC generator", which I presume does the inversion of the AC from the dynamo to DC. If the "change AC generator" is a separate unit, where is it located?
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
TAKEUCHI TL230 SERIES 2 SKID STEER (A64279)
TAKEUCHI TL230...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
