What have you done to your Branson today?
   / What have you done to your Branson today? #561
Branson Bob, what town do you live close to? Nice video! Got the exact same tractor as yours.
   / What have you done to your Branson today? #562
Nice video, nice place that you have.
Lot of work for water in a semi-arid location.
Yes water is precious here compared to NY where it's so abundant. I grew up in Western New York and lived there for 35 years. An upcoming project will be the installation of a solar slow pump to bring water up from the creek.
Thanks Aqua, we're in Mariposa County, CA.
   / What have you done to your Branson today? #563
Cut down a tree that I've been debating dropping for 2 years. We had a high wind event (90 mph) 2 years ago that broke the top out of this tree. There for a while I thought the tree was a gonner, then it actually started to come back for a while. But there was so much tree gone out of it, the remainder was just pitiful, so finally decided it had to go today.
Used the tractor to tug one side down (split trunk) as it was leaning too far towards the fence. Cut the hinge and just pulled it down with the tractor.
Then just used the forks to carry the rest off to the splitter, and the small trash off to the burn pile.
Have to chase down someone with a stump grinder for this one, as it's right in front of the back steps.
   / What have you done to your Branson today? #564
Nice job! Maybe even the stump up a bit and mount a bowl for a bird bath. Then it fits in with the back yard and Mrs Slim will like watching the birds?
   / What have you done to your Branson today? #565
Good work. Is that some sort of locust tree?
   / What have you done to your Branson today? #566
That is a Box Elder tree. They grow like weeds, sprout shoots off of cut stumps (if you don't treat them), get large root balls (lots of surface runner roots also), and are a soft, stringy wood. Prone to breaking off tops when they get really big, and for some reason like to grow crooked. That's about all I have around my place is Box Elders.
This one will get cut and split for camp fire (and home fire pit) use, which is about all they're good for.
   / What have you done to your Branson today? #567
**** I should have recognized them. Box elder are actually in the maple family though not as nice as any of the maples. As you suggest the wood is good for just about nothing though you can make syrup from their sap. Much of their heartwood has that red pith in the center. At least they're light and easy to remove.
   / What have you done to your Branson today? #568
Yesterday I did another test on my branch chopper. It's almost done and it's way less sketchier with all the guards and hoppers on.
I reduced the rotor speed by changing the ratio on the chain drive and added a flywheel which made it less violent.
It will eat stuff up to 2" to 2 1/4". It can go bigger but it's just to much banging on the tractor and will break the shear bolt every once in a while.
   / What have you done to your Branson today? #569
Good stuff Pedro.
I wish I had your design and fabrication skills.
   / What have you done to your Branson today? #570
Rented a walk behind stump grinder yesterday for the final clean up.
It was right out the kitchen door steps, so it was going to be a hazard if I left a stump sticking up above the ground there.
Still have to fill in some dirt around it.
It was fun grinding yesterday in the wind, rain, and snow (yes, it started snowing). At least it melted as soon as it hit the ground.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
(3) ALUMINUM STEP LADDERS (A58374)
(3) ALUMINUM STEP...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
2009 International 4300 Truck, VIN # 1HTMMAAN79H163641 (A57453)
2009 International...
