Bucket Level Indicator Adjustment for Grand L
   / Bucket Level Indicator Adjustment for Grand L #31
Can you show the dimension from the orange indicator plate to the hole in the loader arm?
Like these?
   / Bucket Level Indicator Adjustment for Grand L #32
I've never adjusted the indicator rod since owning but being such a laid back day I decided to. I've read the manual and for no reason at all can explain why I'm unable to make this work. The indicator rod i can get adjusted but the plate I can't. Its almost like the plate isn't long enough. Photo attached is with the bucket level and you can see the plate is out of adjustment. This isn't a needed item but if its on here it might as work correctly. any thoughts?View attachment 651144
Can you try to take a photo from the same angle as the first post. Something is weird.
Everything I've seen so far looks just like mine. I was really hoping for a bracket to be installed incorrectly or something. This is bugging me. It's a easy fix by just building a longer indicator plate but I'm not giving up yet.
   / Bucket Level Indicator Adjustment for Grand L #34
That's why I'd like to see a photo like post 1. Kubota acres bracket looks like yours, the orange bracket looks like it is welded in the same position. Somehow the orange tube looks out of position.
It is. My bucket is level in that photo and the indicator bracket which should be parallel with the orange bracket can't be adjusted anymore.
   / Bucket Level Indicator Adjustment for Grand L #36
Oops, I meant AllByteNoBark. I'd like to see him replicate the photo in post #1.
Something is goofy with your orange tube.
   / Bucket Level Indicator Adjustment for Grand L #37
   / Bucket Level Indicator Adjustment for Grand L #38
I think I see the difference. On mine the lever the rod attached to is straight up and down. Yours is leaning back.IMG_20200418_083450.jpg
   / Bucket Level Indicator Adjustment for Grand L #39
What is the length of the tube/rod connecting the lower set of arms to the upper? Mine measures 28.5 inches center of hole to center of hole.
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
STEEL HEADACHE RACK (A52708)
STEEL HEADACHE...
2014 Nissan Pathfinder Multipurpose Vehicle (MPV), VIN # 5N1AR2MNXEC713906 (A56859)
2014 Nissan...
New Wolverine 78in Skid Steer Land Leveler (A59000)
New Wolverine 78in...
2019 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A55973)
2019 John Deere...
