Speed Reduction for Old Drill Press
/ Speed Reduction for Old Drill Press #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
EDIT: I couldn't figure out how to make the photos work but they are down in Post #7 all glumped together. Sorry.
I have been running this Craftsman Drill Press since I was 14 years old. At that time, 60 years ago, it belonged to a man down the road who built metal tables with ceramic tile tops as a side business. I worked for him part time. 8 years later he became my FIL and I finally ended up with the drill in my shop.
I often wished that it would turn slower than 560 RPM. Wanting an indoor project recently, I decided to slow down the drill - finally. A factor of 3 seemed about right for what I do. So I ordered a set of pulleys and a 1/2" shaft 12" long from McMasterCarr. The pulleys were 1-1/2" and 4-1/4" pitch to give a 2.83 speed reduction ratio and a 200 RPM low speed and 1900 top speed. I also ordered 2 flange bearings and an A21 drive belt from Surplus Center.
First I made a 6-1/4" X 12" motor mount pad with ears on it so it would fit snugly over and be supported by the drill press mounting pad built into the casting. Then remounted the motor so I could continue using the drill.
Next I welded up the C-Frame for the spindle from 4 X 1/4 bar. I pre-drilled the end plates for the bearings and managed to keep it square during welding. This is the first of 2 passes.
I added slotted holes to adjust the pulley tension and assembled the bearings and shaft.
Then mounted the new spindle to the motor mount pad putting the speed reduction pulley on the bottom and the original 4 way drill pulley on top. I had to cut a notch out of the side of the drill casting for the main belt.
While I was at it I mounted a switch box to another ear on the motor mount pad so I could attach a grounded power cord. Another thing I have been thinking I should do for a long long time.
Turned out to be an interesting project and works as it should. Drilling 1" plus holes will no longer be the adventure it once was. Don't know why I waited so long.
gg
Interesting story but it would be better if your attachments would open.
I agree. This new picture thing is weird. They open for me OK. I don't know why they show up as attachment numbers rather than inserted pics. The old way was so easy. I hope it gets fixed.
gg
/ Speed Reduction for Old Drill Press #4
It IS a good story, especially the part when he married the boss's daughter so he could get this drill press. ;)
/ Speed Reduction for Old Drill Press #5
Gordon, I even checked this on my phone and they don't show up on it either. Not sure why.
Ford, I see your point but that could also make for a very expensive drill press. Likely it was worth the price but...???.
Well here are the photos maybe. Can't tell if they are there or not.
EDIT: I guess they are there. Scrambled up but should be easy to figure out.
gg
/ Speed Reduction for Old Drill Press #8
Clever idea and well executed.
And if you ever wanted to take it back up to the original rpm you can just add more step pulleys to the motor and jack shaft.
/ Speed Reduction for Old Drill Press #9
Nice job on adding spindles
I just installed a 1150 RPM vs the 1750 RPM motor on my old drill press. Be nice if it went a little slower but this was well within my capabilities
/ Speed Reduction for Old Drill Press #10
I've never explored the idea but I've often wondered if a small planetary gear set out of a compact automatic transmission wouldn't work. Install it on the quill and you wouldn't have to run the belts as tight to turn a large drill bit.
I like what you did with yours.
/ Speed Reduction for Old Drill Press #11
Looks like over the years, many guys had similar idea's, it's pretty common,
Your's looks like a pretty clean conversion, to slow that spindle down,
SR
/ Speed Reduction for Old Drill Press #12
I have an old Craftsman drill press about the same vintage. Someone added an intermediate pulley. The pulley goes on an arbor that is mounted off center on a plug that just drops into the upright tube. Very slick. Spindle speeds down to 290 rpm and much higher that I never use.
Like SR said mine is pretty routine but that little gem is really really clever. All you need is one small pulley for the motor and two new belts. And if that plug is free to swivel in the tube both belts tighten at the same time with the adjustment that is already there. Too simple.
gg
/ Speed Reduction for Old Drill Press #14
Have y'all considered a VFD instead of adding pulleys?
David from jax
/ Speed Reduction for Old Drill Press #15
I love the design of that old Craftsman drill press. It's a nice balance of form and function, compared to the newer tools that are stamped squared shapes with hard edges everywhere.
/ Speed Reduction for Old Drill Press #16
When the electronics crapped the bed on my Grizzly mill, I installed a three phase motor with a VFD. Works great, even power tapping with the instant reverse. Though I'm not sure about reliability if one was to load it down at low speed for any length of time with a large drill bit. Have done the occasional one inch hole without ill effects.
New/Unused Wolverine Sickle Bar Mower (A65583)
New/Unused...
17601CFL (A59228)
17601CFL (A59228)
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
20' One-Trip Shipping Container (A66285)
20' One-Trip...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2012 International Prostar (A63118)
2012 International...
