   / Your last generator Maintenance Run #3,891
Anymore earthquakes in the region...
   / Your last generator Maintenance Run #3,896
Yesterday we had our first power outage since we bought a generator. Went for a walk and the power returned before we got back.
   / Your last generator Maintenance Run #3,897
The last 2 storms in Maine did not affect my power, but I was ready to go and decided to conduct an overdue PTO generator test. This time I wanted to collect fuel consumption data for an idle use load (no meal prep, no laundry, no cleaning, etc). No AC or electric heat either.
This small load included: 8 LED lights plus occasional lights in the home as I needed them. The refrigerator, dish washer, the latter would cause the .5hp well pump and oil fired boiler to run, and a laptop. I estimate energy consumption in the 1000-2000 watt range.
Power plant: Yanmar 45hp with 32.5hp at the HST PTO, 2400 engine RPM.
Generator: Rural King 16KW, like the Harbor Freight model, Brushed 3600rpm alternator
Duration: 65 minutes (5min warm up, 55min making power, 5 min cool down)
Fuel consumption: 2.5 quarts, I measured it with a stick in the tank and a 5 quart measuring container.
This fuel consumption contrasts with an earlier test that I threw everything in the house as it: add electric oven and range, clothes dryer, more lights, etc. That test consumed 1.25 gallons.
My conclusion is I can expect .625-1.25 gallon/hour use off my 16KW PTO generator, nice to know!
   / Your last generator Maintenance Run #3,898
We have a similar setup, so this is good to know. Thanks for posting.
I have 32.5 PTO hp and a 15kw generator. I'll likely test fuel consumption next time I need to run it.
   / Your last generator Maintenance Run #3,899
I did a full load test this last weekend on my 10k (20k surge) Porter Cable unit. Killed the main, all breakers, flipped the interlock, fired genny, clicked on every circuit in the house. Didn't need the heat on but I made sure the well pump kicked on, both attic and basement air handlers along with our boiler, lights, and I even clicked on the electric dryer. Still put out the right power and hz as checked with my DVOM.
Ran it like that for 45 minutes, reversed all the steps and let it cool on idle control (low idle) for 10 minutes before turning it off, checking the oil again, and topping off the fuel. Ready for an outage.
Train in Peace...... :thumbsup:
..... lately, over-prepared is looking pretty good about now.....
Rgds, D.
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
2017 Autocar Xpeditor T/A New Way 31Yd Side Loader Garbage Truck (A55852)
2017 Autocar...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
2008 Chevrolet C7500 Truck, VIN # 1GBM7C1G78F413329 (A54865)
2008 Chevrolet...
