Battery Post Duplicator?
/ Battery Post Duplicator? #1
ScipioUSA
MF 20 Industrial, Ghosts of Farmalls Past
Hi Everyone.
Im looking to see if anyone knows of something that would allow me to duplicate the posts on my battery. Sort of like the clamps that you can put on that are like a marine terminal with the wing nuts, but that would also provide a second battery post.
I dont want to mess with the factory wiring on my RTV500, but I need to make more attachments to the battery. The plow was hooked up at the dealer, and I already had to re-wire that once. I dont like how the rings are on the battery terminals now, so would like to attach them separately.
Some looking around the web shows lots of options for installing stereos or marine equipment, but I cannot find any of them that will also allow for a re-connection of the stock wiring. I know there are some Group 24 batteries or deep cycle that have both posts and wing nut/stud connections, but I am hoping to get the use out of the battery thats already in the machine.
Anyone have any ideas?
Thanks!
/ Battery Post Duplicator? #4
Search eBay and Amazon ..."battery post adapters" and "battery post connectors"
All kinds of them - cheap.
I did search both sites, and didn't find what I was looking for, which is why I posted here. Only option that looks similar is the Kat5 terminals with a post adapter. Might go that route
/ Battery Post Duplicator? #6
They sell them at just about any big Marine Store, West Marine, etc.... I have several on my boat batteries to run accessories..
/ Battery Post Duplicator? #10
^^ Guys, none of those examples "also provide a second battery post" that he's asked for. Only that one made in Australia looks like what he is describing. I've never seen one like that either.
If it were me, I'd alter the original wiring and use one of the common styles everyone has posted. There's nothing wrong with a good clean mod.
/ Battery Post Duplicator? #11
You can try this site... looks like he has both the positive & negative in-stock & I believe he is out of Washing ton State... 26.99 each with $8 shipping for both.... Not cheap but it is a pretty specialized connector...
Unilug battery terminal – Bench Prep Jigs
Thanks!
I would do the mod, but while its under my first year of warranty, I dont want to do anything that could open up a chance for finger pointing.
Unilug battery terminal Bench Prep Jigs
I saw those after some searching, but its a little steep.
What I did find was this:
Battery Terminals
I think their "bassik" battery terminal with the post adapter is just the ticket. That gives me the side post to keep the factory cables and connections, and a couple of spots to attach the accessory terminals direct to the battery. Im going to order a set, and will let you know how it turns out in the end.
/ Battery Post Duplicator? #13
So I think that is a pretty good option... I have used KnuKonceptz products for years, for audio products... I will say they definitely are not the same solid brass & nickle coating the UniLug connectors are made of..... but for a cost selective solution KnuKonceptz is a good choice.... & at almost 1/2 the price I might give them a try... Like I said I've had good luck with KnuKonceptz product.... (if this was a marine / or extreme off-road application I would definitely be considering the UniLug product)....
/ Battery Post Duplicator? #16
I got one of those red top batteries in my jeep that has 2 positive posts on it. ...Thing was expensive but the jeep is running a electric fan and a few other bolt ons and it needed the extra space.
Thanks for the first hand review of your experience. I agree they dont look as heavy duty as the UniLug product, but I think for what Im trying to accomplish on my RTV they should work alright. In the event that they dont, Ill post back to warn anyone else about it.
/ Battery Post Duplicator? #20
What a great thing to have. Weird. I don't see them anywhere either. I was sure Quick Cable would have them but nope.
2011 FREIGHTLINER FLD120 FLATBED (A65643)
2011 FREIGHTLINER...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
90in. Work Bench (A65640)
90in. Work Bench...
3Pt Bale Carrier (A66408)
3Pt Bale Carrier...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
