1020 gas can't keep it running
/ 1020 gas can't keep it running
It's off to the professionals. 2 days. $110 later. We'll see, but that should eliminate any carb issues. If it doesn't run after that. Big hammer.:shocked:
It's alive :cool2: It's alive :cool2:
Yes, it had 2 clogged passageways. I didn't have a carb kit, so I wasn't going to take it that far apart. Haven't tried it under load yet, but will do that this week hopefully.
Thanks everyone for your inputs :drink:
/ 1020 gas can't keep it running #43
Great to hear it! It always feels good when you get an engine running well again. Good job.
/ 1020 gas can't keep it running #44
I was guessing clogged passages. Glad you got it fixed. I suspect the carb pro ran something like fine wire through all passages.
/ 1020 gas can't keep it running #45
Yup, doing that currently.
Either can be bad, I've used it extensively over the years, but yes it can be hard on it if you're not careful. What i like about either is the metal can.
No better after the soak and blow. Will have carb professionally rebuilt I'm thinking. Least wise will know that part is not the issue if it doesn't fix it.
Since you say you did not have a carb kit, and said you were not going to take it apart further, did you NOT take it all the way apart to soak it?
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
S/A Towable Solar Speed Radar Trailer (A64194)
S/A Towable Solar...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
