Todays shop time.
/ Todays shop time. #941
Not ridiculous, it's very difficult to part with dads stuff.
That's relevant to what I've been doing this week. My dad and I owned and operated an electrical contracting company from 2001-2013, when we closed up shop. I owned the building we used as a shop/office, which I sold last summer, and dad had past away in the spring just before. The new owner was in no hurry for me to clean out the elelectrical materials and tools, and dad's shop... but the new owner called a week ago, it was time to clear out. Lucky I had this week off work... 3 trips with the truck and trailers... now to stuff it in the barn somewhere. Had to leave alot behind, including dad's half finished projects, electrical gizmos and odds and ends I'll never use, or is outdated... can't take it all, had to just walk away, what's left will be going in a dumpster. But I'm glad its done.
/ Todays shop time. #942
This has been a 7 day project, started last Sunday then finished this afternoon... It's hard to make progress during the week, 90 minutes at a time working in a driveway... My Ranger NEEDED a traction bar as bad as anything needed one, I'd taken out two radiators by the pure violence pushing the fan into the radiator partly because of a bad transmission mount and a drive shaft that's too long, I put in a shorter drive shaft too and a thinner radiator but still needed to fix the root of the problem. I think this is my biggest fabrication project on the thing, there's some things I'd wished I'd done a little different (mainly angles I'd welded things after it was too late) but whatever, the thing works perfect... The mockup picture in the driveway was before I cleaned up for paint, I know the other picture isn't great but it was a TIGHT space to fit all that.
The Harbor Freight plasma cutter and Titanium MIG 175 were troopers, I have a 11lb spool of .035" Lincoln flux core in there and it did everything I wanted, only a couple welds were goofy... I think I used all 5 HFT angle grinders I have on this project...
/ Todays shop time. #943
Pretty nice door yard work. I don't know much about that stuff so I had to look at it to see what it does. Must be you have a big motor in that ranger ??????
gg
/ Todays shop time. #944
i have a question about non seize. Want to get a can for general use, spark plugs, etc.
I see there is a choice of nickel, silver, copper and metal free.
I understand if I want to use it on a spark plug, it should be high temp, but could be used on anything bolted also.
Do you have a suggestion for which non seize variety to buy?
thanks
Drew
/ Todays shop time. #945
thanks
Drew
Permatex is a good product Drew. I keep a can of the aluminum in the shop.
Here’s more info.
Permatex(R) Anti-Seize Lubricant - Permatex
/ Todays shop time. #946
/ Todays shop time. #947
I like the copper never seize, that's what I try to keep around. Also, it doesn't take much, so you don't need a big can of it.
SR
/ Todays shop time. #948
I tend to try and keep a Nickel one around it seems to work the best for anything stainless steel with threads,
I also have the Silver on hand.
Loctite Anti-Seize | What Type Do You Require?
Back many years ago I used to use a lot of Chesterton Spray Nickel,
a shot of that into a SS fitting, and on the nipple three wraps of teflon tape and never have a leak or a galled fitting,
which was quite common when working with threaded SS.
/ Todays shop time. #949
NO NO NO anti-seize on spark plugs. Heat transfers through the threads, mucho problems if that doesn't happen.
/ Todays shop time. #950
I like to use it on mower blade bolts also. They tend to self tighten and rust if neglected too long. Better mechanics use it on exhaust manifolds / systems
/ Todays shop time. #951
Anti seize especially with metallic particles is going to transfer that heat just fine, it is not a thermal barrier.
I have been using a bit of never seize on spark plugs for many decades on motorcycles, snowmobiles, tractors, trucks, utv's and I don't recall a single issue
with that practice. For a while some plugs even came with a strip of never seize pre applied, I don't recall the brand or the application right now but I remember purchasing some.
I also use di-electric grease on spark plug boots.
/ Todays shop time. #952
Guess I'm just showing my age. When I did my apprenticeship, starting in 1967, our books showed the distinct heat flow path of hot and cold plugs. Did a quick search and see that under certain circumstances the compounds are recommended. Learned something today.
/ Todays shop time. #953
Thanks guys. I originally thought the aluminum might be best for aluminum heads/spark plugs, but
I am sure no engineer or mechanic.
Let's look at this from another direction, are any of these a bad idea in certain situations, like metal mismatch, or thermal issues?
Just seems that using anti seize is a good idea. We all have rounded off or broken bolts and screws trying to get them out.
/ Todays shop time. #954
Aluminum has more in it than aluminum. For general purpose I would use Aluminum.
/ Todays shop time. #956
Just be aware that it is very difficult to remove once it is gotten onto something...
Disposable gloves are recommended for installing it.
The food grade white stuff is a little bit better, but it still makes a mess.
Aaron Z
/ Todays shop time. #957
Aaron, I always thought that Loctite was used to keep nuts and bolts from coming apart, but anti seize was used for items one wants to come apart
at some time in the future. So yes, I want the one that comes apart. And I'll wear gloves...thanks.
/ Todays shop time. #958
Permatex and Loctite make a lot of products. In my younger years Permatex made gasket sealers and Loctite made threadlocking products. Today they both make a full line of products for home and industry.
/ Todays shop time. #959
gg
Thanks,
I just have a turbo 4 cylinder so around 200hp but low range and lift blocks turn that into a lot of torque that twists the leaf springs around.
/ Todays shop time. #960
Should've done this mod a while ago. Added a Wixey Digital Readout to my planer. Wow! Now I can dial it in to .005in accuracy in a jiffy. Always hard to go back and make additional boards at the same thickness without a lot of fussing using a tape measure or rule on the machine.
Thinking I might 'need' one for my table saw as well. :cool2:
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
1500 gal Poly Tank (A66408)
1500 gal Poly Tank...
New/Unused Wolverine Mini Quick Attach Pallet Forks (A65583)
New/Unused...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
