XR3135 rear tail lights
   / XR3135 rear tail lights #1
cford36
Gold Member
Western, NY
LS3135HC
Had a burned out brake light. Turns out bulb was broken because the plastic locking ring is destroyed. Seems like the heat made it brittle. Anyone have a wiring diagram that shows the part number the wire harness for the tail lights? Just the last foot that splits aft the disconnect. (XR3135HC)
Replaced the otherside with an LED while I was at it and that ring was also disintegrating.
Thanks.
   / XR3135 rear tail lights #2
I should replace my taillights with LEDs also. I have felt the heat of those incandescent bulbs. My tail lights are on any time the engine is running.
Any of the dealers on here post a pic of the schematic that shows part numbers for the rear lights?
The housing that these lock into are plastic also. I found that the one that broke was out of the housing because the housing was bent out at the top. It was either a bad part to start or the heat allowed it a slowly bend till the light feel out.
I would highly suggest changing to LED.
   / XR3135 rear tail lights #5
Thanks.
I actually had issues with both brake light lens on my tractor. I went through a local New Holland dealer for replacement parts. Exact same taillight assembly. My thread can be found here.https://www.tractorbynet.com/forums/ls-tractor-owning-operating/372191-brake-light.html
See post #10.
   / XR3135 rear tail lights #7
Actually I found the bulb numbers I bought from that post. You don’t by chance have the actual part number for the housing and harness your ordered?
The New Holland part #MT 40261651. I think they were about $36.00 per side. You get the red and amber lights with wiring harness. If you want to take a look use the NH website which is actually very nice site. If you go into model/tractor/compact/Boomer.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
KUBOTA SSV65 SKID STEER (A52706)
KUBOTA SSV65 SKID...
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
Self Dumping Hopper (A53316)
Self Dumping...
John Deere 2120 Tractor (RUNS) (A50775)
John Deere 2120...
UNUSED Mini Excavator Hydraulic Thumb (A47477)
UNUSED Mini...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
