Ls same engine different hp ratings
/ Ls same engine different hp ratings #21
Most of the manufactures have several models with the same engine and different hp ratings.
Just look at International and the DT466, between several different tractors, combines and trucks
with a multitude of HP ratings from 150 to over 300 Horse.
/ Ls same engine different hp ratings #22
I did some checking on the ECU programming with Ekotune.
The LS/New Holland can be programmed but not with a handheld tuner. The ECU would have to be opened and a Transdata system used to program it. So currently it is not that simple of a process.
/ Ls same engine different hp ratings #23
If any of y'all come across a viable option.....please let me know. We had a pretty rough winter and if I could bump up from 40 hp to 50-55.....it would help me blow the snow a bit better......don't really want to trade the tractor in to just add the extra hp.
/ Ls same engine different hp ratings #24
Does anyone know if adding a turbocharger is an option on these three cylinder diesels?
/ Ls same engine different hp ratings #25
One person's unhappy saga adding a turbocharger to a Kubota:
https://www.tractorbynet.com/forums...97525-i-still-hate-my-tractor.html?highlight=
https://www.tractorbynet.com/forums...11706-i-still-hate-my-tractor.html?highlight=
In one of Ted Coriher's videos for everytfhingattachments.com, in which Ted turns up the power on a New Holldand, he warns of cooling issues as if run at full throttle for long.
/ Ls same engine different hp ratings #26
They've already got one. The cutest little baby turbo I've ever seen. Did you miss it? I wouldn't hold it against you if you did. Or do you mean add an additional turbo?
/ Ls same engine different hp ratings #27
I was told that the turbo was only used to put more air to pass the EPA. I would think that LS might offer a power upgrade for a fee if the programming is the only difference. That would mean that it still passed the EPA and would not void the warranty. Putting out more power, I would think is more wear on the engine and tractor. Hence higher cost of the warranty.
/ Ls same engine different hp ratings #29
I ask my Dealer about that and he said that if they had to replace the computer they had to furnish the S/N and then they get a program to flash that computer only , so a sneak upgrade through your dealer wont work and he said you cant pay for a upgrade hp boost front LS.
Im sure someone is going to have a work around this soon.
/ Ls same engine different hp ratings #30
Exactly, the motor parts are the same. On the Boomer I found one difference - the air cleaner changes at 45 and above.
Do you know how they are different and if the air cleaner can be retro-fitted on a 40?
Thanks
/ Ls same engine different hp ratings #31
I have a 40 hp and my dealer said they could up the HP with their computer but he wouldn't do it because he wants to keep in good relationship with LS .
/ Ls same engine different hp ratings #32
Thanks
It's larger and yes it will fit. You would also need the air cleaner clamp and hose that goes from the air cleaner and airflow sensor.
I believe I have all that from my Boomer 40, but I'd have to double check. If you're interested send me a PM.
2012 Mercedes-Benz 2500 Sprinter Van (A61573)
2012 Mercedes-Benz...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
1996 Ingersoll Rand 185 Compressor (A64047)
1996 Ingersoll...
2017 AVENGER TRAVEL TRAILER (A63569)
2017 AVENGER...
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
