Rear Rake with Wheels & 2 Hydraulic Rams
   / Rear Rake with Wheels & 2 Hydraulic Rams #1
Oldtoad
Kennebec County, Maine
Kubota L4310, Bolens-Isiki
   / Rear Rake with Wheels & 2 Hydraulic Rams #2
Most of all rake covers your wheel track at 45 degree setting,I would lean towards 8' rake.
Thanks.
Have to dig out the Hypotenuse, Tangent and Adjacent calculator to make sure the 45* angle covers the tire width.
Never could remember those relationships...
   / Rear Rake with Wheels & 2 Hydraulic Rams #4
There is almost no limit on rake size for a 40HP tractor,,
This is my 40HP tractor with a 7' rake
Anything that tractor can do with that rake, I can do with my tiny JD 650 17HP tractor,,
The only reason the rake is ever put on the 40HP tractor is that the larger tractor has hydrostatic drive,, instead of the gear drive that the 650 has
Your checkbook is the only limitation,,,:thumbsup: :laughing:
   / Rear Rake with Wheels & 2 Hydraulic Rams #5
Thanks.
The square root of "A"squared + "B"squared = C
Ok, thanks.
Groogled Right Triangle Calculator
Did 2 widths of rake 7' and 8' as the hypotenuse.
Raked path width @45* is 5.0' for the 7' rake and 5.7' for the 8' rake
According to owners manual tractor is 62.4" or 5.2' wide, soooo, it looks like an 8' rake would cover the wheel track but if a 7' rake was a real deal, we could make do...
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2016 New Holland Boomer 47 (A53317)
2016 New Holland...
