Diisel Gator holding prime
/ Diisel Gator holding prime #1
Roy S
2006 Diesel HPX 4X4
I have a 2006 HPX diesel and it will not hold the prime. It runs great but i have to prime it every time i want to start it. Is the check valve in the delivery pump? or elsewhere?
RoyS
/ Diisel Gator holding prime #2
Im not certain about that engine but most of them rely on the valves in the supply pump to stop the flow back to the tank..
Install a clear line from the supply pump to the filter. & run it.. then when full. shut it off & wait till the next day to see if its still full or empty.
If its empty, u know the supply pump is allowing fuel to drain back..
U might be able to take it apart & check the valves for debris.??
Thank you, the clear line is a good suggestion.
2014 Timpte Hopper Bottom (A63118)
2014 Timpte Hopper...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2015 FREIGHTLINER...
ALUMINUM HEAD ACHE RACK (A63569)
ALUMINUM HEAD ACHE...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63118)
2012 Freightliner...
