Diisel Gator holding prime
   / Diisel Gator holding prime #1
Roy S
2006 Diesel HPX 4X4
I have a 2006 HPX diesel and it will not hold the prime. It runs great but i have to prime it every time i want to start it. Is the check valve in the delivery pump? or elsewhere?
RoyS
   / Diisel Gator holding prime #2
Im not certain about that engine but most of them rely on the valves in the supply pump to stop the flow back to the tank..
Install a clear line from the supply pump to the filter. & run it.. then when full. shut it off & wait till the next day to see if its still full or empty.
If its empty, u know the supply pump is allowing fuel to drain back..
U might be able to take it apart & check the valves for debris.??
Thank you, the clear line is a good suggestion.
2018 FREIGHTLINER M2 106 26' REEFER BOX TRUCK (A54607)
2018 FREIGHTLINER...
Set 4- 10-16.5 tires/wheel for bobcat (A55787)
Set 4- 10-16.5...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
2005 JLG Skytrack 8042 (A47477)
2005 JLG Skytrack...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
