What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,131
   / What did you do on or to your LS Tractor today? #1,132
Did not do a lot, but used the loader to lift and place the big brown planters in a new landscape bed. Then got 6 bucket loads of mulch to finish it off.
   / What did you do on or to your LS Tractor today? #1,133
Very interesting setup. It looks to work very well. Kudos
   / What did you do on or to your LS Tractor today? #1,134
Looks like it works just as well as the rich mans grapple! That was a bunch of debris!
Thanks, works pretty good except for the little stuff has to be picked up by other means.
Nice job on your Son's garage build, I've been following along!
   / What did you do on or to your LS Tractor today? #1,135
Thanks, he will be posting new videos soon. He just completed staining the concrete floor last weekend, let it dry all week, and will be doing the top clear coat this weekend. He will probably post that video soon.
   / What did you do on or to your LS Tractor today? #1,136
Not nearly as glamorous as you guys, but
3 buckets of dirt to fill and backfill my block wall
And delivered 14ft pallet to neighbor for their bee hives.
   / What did you do on or to your LS Tractor today? #1,137
Had been experiencing the S97 F02 error code
Water in fuel.
This was not a consistent error, didn稚 happen every start and often went away.
So today I replaced both the Fuel filter and the water sensor assembly.
I am curious that the sensor may be OK, just clean it up.
Anyone else with this experience?
Thoughts?
Did you drain the filter first because if your getting wet fuel it will just happen again mine did it at about 200hrs i drained the filter and its been fine since! In your humidity area i suggest always keep fuel tank topped off less are space less condensation! And keep extra fuel in a place that dont change temperature best you can keeps condensation down some!
   / What did you do on or to your LS Tractor today? #1,138
Not until I changed it. Better understand how it works now which leads me to believe the sensor is still usable. I’ve cleaned up the old one and placed in the bag the new one came in.
When replacing the fuel filter intself I think next time I will attempt to prefill with diesel before installing to reduce the amount of hand pumping.
   / What did you do on or to your LS Tractor today? #1,139
I go through periods when I get fuel with water in it. Filter will get full and throw code. Drain filter and clean off sensor and keep working. After a couple of times doing this, the v fuel B is b cleaned up and I can go several tanks with no problems.
   / What did you do on or to your LS Tractor today? #1,140
Good to know. Thinking I may even dry out and keep the filter for emergency. Assuming dealer changed at servicing so only about 50 hours.
20704 (A55853)
20704 (A55853)
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
