Box blade mod
/ Box blade mod #1
600rider
Gold Member
union city pa
2004 kubota b7510
This won't be too long but I think it's a good mod.
I built this box blade many years ago because to find one like it was very expensive. The rippers rotate hydraulically. After many years of frustrating use because it doesn't angle I watched a YouTube video that a guy made an extension to angle one side. Looked at mine and thought I could do something like that. So being in Coronavirus jail I set out to make the mod. It was quite easy for this bb because I used 2 square tubing for the hitch. I started by cutting of the left side pin. Found a piece of 1.5 square tube that was close to sliding inside the 2" And "worked" it with the grinder until it slid in with ease. Drilled some holes and welded the lift pin to the 1.5 sq tube. It looks like it should work but I have not tried it yet.
image0 (1).jpegimage1.jpegimage2.jpegimage3.jpegimage4.jpegimage5.jpegimage6.jpeg
/ Box blade mod #2
/ Box blade mod #3
HAHA :thumbsup:
/ Box blade mod
working on them! Having trouble getting the pics up please bear with me as I work through this technical difficulty.
/ Box blade mod #5
View attachment 647634View attachment 647635View attachment 647636View attachment 647637View attachment 647638View attachment 647639View attachment 647640
Only angles to one side?
/ Box blade mod #6
Innovative!!!! Anxious to hear reports of how it works!!!
/ Box blade mod #10
I don't care one iota about angling my BB...but the design of the hydro rippers is pure genius...please post a few more detailed pics...the ends for instance...:thumbsup: :thumbsup:
/ Box blade mod #11
Not to hijack this thread but has anyone put a trailer hitch on a BB. I use mine as ballast for the FEL. Would like to be able to fill trailer then just use 3PT to hook to trailer and move it around property.
/ Box blade mod #12
Nice work!
So what degree of angle did you end up with? For reference, one degree would be just under a half inch on a CAT1 hitch spread. (About 28 inches center to center)
The angle on the blade should increase cutting ability due to the shearing action so will be curious to hear test results.
Now just need to add a small cylinder alongside the extension to adjust on the go. :)
Then it would be a T&T&A. Right? Or perhaps TNTNA?
/ Box blade mod #13
I have a ball straight on the top of my boxblade similar to the one the OP has. The problem is it’s a little too high. It needs a 2” receiver to use a drop hitch.
/ Box blade mod #14
Mine is in this thread.
I got the mount off of amazon for a John Deere gator. It was cheaper than if I had made it.
2" trailer ball on box quick hitch
https://www.tractorbynet.com/forums/showthread.php?t=312608
I too am interested in seeing details on the hydraulic scarifies.
/ Box blade mod
Nice work!
I am not sure what the degree is but I have two positions I can angle it to they ar 5" and 6" so I guess doing the math using your 1/2" per degree is 10* and 12*. A cylinder to angle it would be nice but the rear hydraulics are being used for the top link and ripper rotation. It is raining here in Northwest PA so I won't be trying it any time soon.
/ Box blade mod
I will see if I can find the video of them. If not I will get one once it stops raining.
/ Box blade mod
if you look in the first picture you can clearly see that I have a ball mounted on the back of the bb
/ Box blade mod #18
An 8' landscape rake does the same thing, no modifications, pull 1 pin and rotate the angle out to 45 degrees. Most users don't get the notion that you need to put a few hundred pounds of weight on the rake to make it dig, but that's really all you need for gravel driveway or roadway maintenance. At the high angle the tooth spacing as seen by the stone is about zero, so it combs the material towards the center. It also smooths out any ruts or roller coaster mounds. Yes, you need gauge wheel behind the rake to maintain the gravel spread with a chain for a top link to get the smooth, level and combed results.
/ Box blade mod #19
If you look at the pics in first post, he has a trailer ball on the back of his BB.
/ Box blade mod #20
I hope the OP reports back on how it works for him. It should allow the gravel to move to the center of the drive to get a crown easier. :thumbsup:
2018 CATERPILLAR 262D SKID STEER (A62129)
2018 CATERPILLAR...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2025 AGT Industrial SDA-140W (A60463)
2025 AGT...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
