Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 13,312
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
Had to wait on warmer drier weather. This is a picture of the left side looking up where the mounting plate will go:
Bolted the step to the mount and clamped in place as low as it would go to check fit:
Decided to use some self-threading bolts that I had:
Drilled two holes at the top next to their holes, so they wouldn't be too high and 4 holes at the bottom of the mount where most of the force from my weight will be pushing out against the bolt heads:
Clamped the step and mount in place, drilled 6 pilot holes and bolted it tight:
The top two bolts were harder to get in. The pilot holes felt like they went through thicker metal.
Found out why when I opened the door. The two top holes that I drilled are too high and went through more metal:
Looked at the directions and see that by putting it where the step is lowest, the mounting plate is upside down.
Right way, the top holes are lower and my way, the top holes are higher:
The step is halfway up to the floorboard. Makes it much easier for this old man to get in and out :thumbsup:
