Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #6,581
Keep the old rotary alive enough to do your first pass. Let it eat the heavy stuff & rocks. You arent likely to cry to hard when the beater dies. Then look at a nicer mower to maintain things.
Not a fan of some of the light cheap Titan impliments like mowers. I'm happy with their pallet forks, but there arent really parts you need for repair on those.
Given your stated history, I'm going to strongly "2nd" what Fallon said. And I'd actually ante a few morsels here:
A) do you have spare blades, bolts, pieces already for the Frankenstein mower?
B) Maybe even a spare/backup gearbox?
C) given your experience & learning curve are so high with the Frankenstein, how fast (do you believe)would you be able to fix it and be back 'cutting the trail'?
D) if funds are too tight, then I'd suggest a couple months with Frankenstein to add some extra scratch for the "new to you flail" that's around that $1500 & ordering a spare set of blades and hangers etal so you will start out with a shortened learning curve.
E) that way it's Dave Ramsey style 100% down & nothing a month.
/ Let's talk flail mowers #6,582
Thanks for the comments. The old brush hog is still functional - I just need to do some more welding on it (already put a new deck on it, reinforced some other areas) - I just need to weld up some cracks on the tail wheel support, weld up the rear skirt some, and tighten up the blade mounting (the blades loosen quickly enough to contact the deck, which eventually opens it up like a can opener, this is what's caused me to rebuild it twice before). No big deal. It's not worth anything to sell, so I'll certainly keep it for rough duty and grinding up the rocks! I don't have any spares for it, anything that was replaced was scrapped long ago.
I'm keeping my eyes open for a used, but they don't come up often around here - hence why I was looking at the Titan pricing. Once the trails and a few areas in the woods are cleared (putting up a couple of log lean to's for camping down by the ponds), most cutting should be fairly light duty.
Thanks again.
/ Let's talk flail mowers #6,583
Hey @JohnBoyHunter I just did a Craigslist search around you..... Either I'm not using the right words or your neck of the woods have almost no shredder mowers.....
/ Let's talk flail mowers #6,584
Rotary cutter, bush hog, brush hog, rough cut mower. Shredder isnt a common term here in Colorado & I only figured out what they were from context on other TBN posts.
/ Let's talk flail mowers #6,585
Yeah, I used those terms as well & found 3 finish 3-pt mowers & a single post of bush hog parts. Ohhhh & a Ford flail for $1500 that's either a 907 or 917 model.
/ Let's talk flail mowers #6,586
Given the vastness of the wisdom on this thread & its mixed amongst all our banter simultaneously, I've spent some time scanning back thru the thread for: details, pics, name & part #'s & websites.
Found these sites:
Alamo/Mott Flail Montage Enterprises
Alamo Models Parts Listings & I went to these two:
Alamo AC6� (May-91) Parts Diagrams
Alamo Brahma 6� Archive (Jan-96) Parts Diagrams
Clean Cutter Tiller Blades
TractorJoe
and even though they are supposedly closed down since November of 2019 their info is still up and PDF catalogue still available
http://flailmaster.com/our-products/
Regarding the advice that the Ford 917 model can use some/certain Alamo/Mott flail blades I couldn't figure out how to scan-search for what will swap in "plug n play" style?
Thanks to @TheFarmerInAdell for posting the picture in post #6576 that is from the Flailmaster PDF. The bottom of page 23 for the Ford 917 specific blades/hangers etal.
If you look at the top of page 2 on the Flailmaster PDF for the Alamo/Mott blades there is the "fine cut" model #MH-386. Is there any data that anyone has showing/proving (past experience?) these are too long to try and use in the Ford 917?
If you look at this page from clean cutter in California, it gives the size & measurements of the blades that match the pictures and measurements of the craigslist ad I am referencing below.
http://www.cleancutter.com/CL102086.htm
As a comparison from the Messicks PDF for the Alamo/Mott mowers [Model # AC60 and the AC60 Brahma from the archive] have the same looking blade but, the measurements are not something I have found yet..
I ran across someone on craigslist selling off a bunch of them... IIRC they have about 155-ish blades left. They measured them and said each "almost L shaped" blade is 1 1/4" wide, about 5" tall, is sharpened on both sides & is stamped with MOTT.
That would mean I'd still have to find & buy a bunch of the hangers, clips, as well as a bunch of bolts & nuts to mount them.
The hangers via Messicks are almost $6 each & the Blades are $5-8+ each.
Bolts & nuts are solved via the bigbox store given their size is 3/8" X 1"(OR 1 1/4") 16 thread pitch Grade 5 full threads from the Messicks PDF.
That being said. To clarify, recap and finish my post.
How would I figure out if these "Mott stamped blades" on craigslist are too long for the Ford 917 mower?
Is there a needed distance for flow of the cut up debre/mulched grass/etc as well as the tip of the blades minimum distance to the rounded shell of the housing that the 3-point arms are bolted to?
If so how much and where should I try measuring? (There, I hope the focus was better this time and the dyslexia doesn't byte me this time)
/ Let's talk flail mowers #6,587
The MH-386 will not work. Go down to the 917 section of the Flailmaster catalog and it says the measurements of the 917 fine cut blade at 1-1/4" wide 3-1/2" tall. You could use the MH-293, but it will be shorter than the Ford version. I would suggest the airplane wing blades in place of going to a fine cut as you already have the hangers and brackets for them. This will give you a nice flat cut. If you want a very high quality cut you can switch over to the fine cut, but stick with the Ford blades.
/ Let's talk flail mowers #6,588
Well you have 1 Brit & 3 italian companies, seems like italy has more competition and therefore potential for better product. I only know that Maschio (Maschio Gaspardo) enjoys a very good reputation, but that could be due mainly to better marketing.
/ Let's talk flail mowers #6,589
Some dents in the back of my 917 they I really cant see in these photos lead to the knives hitting the hood. When I got the flail ($100) it was missing knives, presumably to combat this issue. I cut out & patched a large chunk of the rear of the hood & replaced knives to fix this.
Which is probably a long way to say there is probably between 1/4 & 1/2" between the knives & hood when its it's running right. I can't comment on what blades may or may not fit beyond ones designed for a 917.
Yes you can also see the cracks in the hood in the missing knives photo. I never did bother getting around to dealing with those as it ran fine (for a $100 mower), if a bit noisy. Ran it for 2-3 years like that before retiring it & upgrading to a Peruzzo Brush Bull. IMG_20150525_185656.jpgIMG_20150613_203410-1.jpgIMG_20150529_181633-1.jpg
/ Let's talk flail mowers #6,590
Airplane wings and Y blades are different. Airplane wings are a folded one piece blade that is flat across the bottom (factory option on Ford mowers), Y blades are a pair of blades that when mounted together look like an upside-down "Y" hanging from the mower (factory option on Mott/Alamo mowers).
If you look at the picture below the airplane wings are on the left and the Y blades are on the right:
Both will fit the Ford mower, but don't try to mix-and-match them. All one or the other.
I have had good results with the flat wings, I do sharpen with a hand grinder.
/ Let's talk flail mowers #6,591
So an update on the 917. I finally had a nice day to prep stuff for the mowing season.
Dismounted the 3-PT BH & hooked up the 917. Did a fresh inspection.
Lubed all zerks.
Tightened the belt tensioner, quite a bit....
Tested out the PTO of the flail. Spun up rather smoothly... from idle up to ~1700 RPMs. Once I had the belt tension adjusted good. Even thought I still need to order blades and stuff.
After this weekend's rain I plan to test it out - whether or not the replacement blades have arrived..... Just a few minutes to see how it feels.....
Thanks y'all for all the wisdom.
/ Let's talk flail mowers #6,592
Okay, technically it's now "Monday" but, 'yesterday' I went a head and did a systems check and tested the 917 on a absolutely saturated back yard that had some varies growth. The missing 5-6 blades did have a noticable but still mild vibration while running.
The Cub cadet is claimed to be a 25hp unit. The 7260 (for refresher)
Here's the edited down pics of a test mowing and a post mow shot that one of our OES's is inspecting.
The trench I dug as part of a upgrade for drainage from the gutters. To get past the chicken coop. with the constant on/off rain its been very difficult trying to finish this all.
This 1st go at mowing with the 917 was a pleasant surprise. yes the accoustic signature was definately different, a much 'lower roar, if i dare say it. compared to the Bush Hog finish mower.
I did have to run the tractor at the 2300-2500 RPMS which is the "desired" 540 PTO RPMs but, that wasn't so bad.
I was able to cut 80% in M 3rd and occasionally the high spots were a drop to M2 gear and it did fine. The forward roll given the top link needing adjustment means next time I won't try to mulch the terf on a couple divet areas.
but, that yard is sooo saturated. over 8" this month alone......
Oh yeah, and I'll be solving the bolt that spun out and disappeared(purple arrow).... drain and fill the gearbox when I do that too.
/ Let's talk flail mowers #6,593
Looks nice. Get them blades on and you will have a winner for sure. I get my blades from flail master. You may want to get a whole set, and keep the old ones as spares. You will lose an occasional blade or two from rock strikes. Also, avoid wire. If you are not sure there is wire where you mow, walk the area first. Trust me, wire is no fun at all. I learned that lesson the hard way, twice!
/ Let's talk flail mowers #6,594
How wide is your 917?
/ Let's talk flail mowers #6,595
Be sure to keep your old ones Flailmaster closed a little while ago(nothing to do with the present virus problem)
With all the hits business is gonna take this year they may not make it back. A sad thing, good friendly people there.
/ Let's talk flail mowers #6,596
I see I have had my Hayes Flail mower for 4 years now. Didn't realize how fast time went by.
It has been marvellous. No problems, gearbox is still showing no signs of seepage. I sharpened the hammers for the second time recently and it has done a lot of acreage which has included small brush, lantana etc. (few rocks too) Paddocks look great. Happy to recommend Hayes for sure.
Kioti. Fastest tractor on the east coast - YouTube
/ Let's talk flail mowers #6,597
dude, sorry for delay... I guess my phone post failed to show up a few weeks back when I first saw your question.
my 917 is I.D.'d as a 74" wide so its a 6' mower.
/ Let's talk flail mowers #6,598
So, last week, I swapped all blades out and replaces several hangers and hooks and bolts.....
Went out and mowed, then had the kiddo's out and learn the new mower.... after about 15-20 minutes for each of them the smiles showed up. The 12 y/o was initially scared to even move the 3-PT lever.... but, after we got thru the double stage clutch and hand throttle.... she was smiles and "hey this is fun." The 21 y/o was like, "that was so much faster and my butt isn't sore from the rough ground like the 46" craftsman riding mower....
still need to deal with that bolt on the gearbox..... but, its been rain and now brisk weather ....
/ Let's talk flail mowers #6,599
So I figured this might be the thread to ask this question on. I have the chance to buy a Del Morino 132M. It was purchased last year by the owner and he is willing to sell it to me for $3000, it was used maybe 3 times, he's selling it because he tried running it on a subcompact tractor, and tractor was to small. I don't even own a tractor yet (LOL) but I want a mower like this for mowing my pond and some ditches. I am looking at probably getting a Kioti NX5010 (In the next few weeks, just don't want to miss a deal if its worth it). My question is, is the mower worth the money (I know they are about $4k, new but I see the other Chinese ones for low $2k's and will the size tractor I'm looking at be sufficient for this thing? Any words of wisdom much appreciated!
/ Let's talk flail mowers #6,600
That tractor should just be big enough. You will want a loader on the tractor and loaded rear tires to keep the tractor stable enough.
A ditch flail when it hits a solid object will tend to twist the whole tractor to pointing downhill. On a pond bank or steep ditch, it happens fast. A heavy stable tractor is your friend here.
1999 Ford F-150 4x4 Pickup Truck (A61568)
1999 Ford F-150...
2012 Ford F-450 Service Truck (A61568)
2012 Ford F-450...
Vertical Steel Well Tank (A61570)
Vertical Steel...
New/ Unused Wolverine 72in Quick Attach Grapple Bucket (A61166)
New/ Unused...
2018 Chevrolet Silverado 2500HD Knapheide Service Truck (A61568)
2018 Chevrolet...
1999 Pro-Trak Trailers PTGN30DT Flatbed Gooseneck Trailer, VIN # 5BNDG302XXC001599 (A61165)
1999 Pro-Trak...
