I am running an L3240 with the factory L2221 3rd function valve kit to run my grapple with. When running it the other day, somehow, a branch snagged the wire running into the switch on the lever and pulled it out completely. When I tried to put it back together the switch no longer works. From the kubota parts diagram, it looks like # 7J417-84153 is the switch/wiring assembly. I'm wondering if anyone has had to replace this switch, and if so, if it's the right part? I was hoping I could plug the wire back into the switch, but that doesn't seem to work... given the shutdown of pretty much everything, it would be nice the have the tractor to catch up on all the yard work! Attached is a pick of the parts diagram. I can get actual pics of the switch later if necessary.
Input is appreciated!
