rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,980
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Have two tractors with that same switch. B26 placement is such it is easily turned off/on by your right leg. M59 has better clearance. Still the switch is plastic and kind of flimsy compared to other switches like the hazards or lights.
See metal, 16mm, led indicator, waterproof similar switches on eBay that might work. Size matters so if you could give diameter that would be helpful.
Installed small led rubber grummet mounted trailer running light for the B26 brake warning light. 3/4” hole. Very bright, obvious and installation is easy.
LED for warning lights just make sense. All this stuff is so cheap that it doesn't make sense to me to buy low price. If quality is more interesting than price, check out McMaster.com. They have been suppliers to gadgeteers, engineers, and fabricators for over a generation now. Top notch outfit and they have everything.
