Grader/Scraper Build
/ Grader/Scraper Build #1
redheelerdog
The Sticks of Montana
1944 Farmall M 2007 AGCO ST34
Here's the beginnings of a grader scraper modeled after EA's Land Shark. That thing is so awesome, when I saw the pics and vids I said to myself, "****, I need to build one of those!" - I could buy one, but where I am located in the sticks of Montana freight shipping is a hassle. But the biggest reason for building one is, I love building things, keeps my mind and hands active! Props go out to Everything Attachments for such an awesome design.
I have about an 1/8th of mile of dirt road I need to work, it's all flat and easy to work. Snow and winter get's it puddled up and it needs a re-doin a couple times a year, probably do some of the neighbors driveways too, I know they would appreciate it.
I had the side plates sheared at the steel place, also bought some angle and strap.
I bought an 8' cutting edge (plan is only one cutting edge - maybe add a second later) and some scarifiers with pins.
I had some left over 4" heavy duty box tube (this stuff is expensive) from a welding table I built last year.
Walleren' the holes out is a chore, not too bad though. After the 12th one I got darn good at it, lol.
Tweaked the holes with some weld metal to make the tines even. Only one was off about a quarter inch.
Added pin clips
Setting on the ground it came to me, Dang, I'm going to need a bigger tractor! LOL - Oh well, go big or go home!
/ Grader/Scraper Build #3
This is my DIY landplane,, and the tractor that pulls it,, it uses 7 foot cutting edges,,
I did hook it to my JD 4105 (41HP),, the 7 foot landplane was WAY too big for it,,,
/ Grader/Scraper Build #4
Gonna need a bigger tractor for eight ft. Built my land plane with two blades at six ft, My Massey 1742 will stop fwd motion if I let it fill up. I have a hydraulic gate on the back to limit material flowing out. Was playing out in a pasture building a dirt bike track in the summer.
/ Grader/Scraper Build #5
Added pin clips
Keep posting your progress / pictures. I am currently gathering the metal to build one also. I was not planning on the cutting teeth though. I just picked up two 8 ft cutting edges. I am only planning on making it 6 ft wide
Hmmm... maybe I will cut the ends off and make it 6 foot wide? My gut feel is that will be a better way to go with my Agco ST34. My road is flat with no grade.
/ Grader/Scraper Build #8
When I built mine, I purchased a couple of nos blades. One serrated and the other straight. Bad idea. The serrated one will pick up a rock and totally screw with the finish on the drive, leaving a gouge till I remove the culprit with a hammer. Have to keep an eye on it constantly. Back up cam would come in so handy.
/ Grader/Scraper Build #9
Nice ! We built a 3 meter wide drag from I beams years ago together with neighbours. I can still pick it up if i need it, but im thinking of making a 2 meter wide version to do some work in gardens with my 3011.
/ Grader/Scraper Build #10
Very nice work !! Keep the pics coming. Just for reference mine has two blades and weighs about 650 lbs. It is 5' wide and I pull it with a 30 hp 4WD L3010. When it is running near full it is all my tractor wants. With a single blade I could go wider. You will like the job it does .....
gg
/ Grader/Scraper Build #11
Following your progress!!!
That shop definitely needs some projects going on. Way to clean!!! :)
gg
Thanks for the info Gordon, I think I am going to cut the ends off so there are only 4 tines instead of 6, cut it down to around 80" wide. I will only have one cutting blade to start, but will have a second angle iron for the ability to add one later. I also have a hydraulic top link so that will help fine tune it. My tractor is 34hp.
Only 2 years old, built the entire thing myself 30'x60' steel, I love it clean! :thumbsup:
/ Grader/Scraper Build #14
I am the same way, I like a clean shop too.
My method is to work until I cannot find a tool that I need, typically every 2-3 hours. If I cannot put my hand immediately on a tool, I stop, then put everything back, and then start again.
It only takes a few minutes, but it saves me tons of time in trying to find tools. My enjoyment comes from the project itself, and NOT hunting for tools. A place for everything, and everything in its place!
/ Grader/Scraper Build #15
As for a grader, I built a homemade one as well.
I plan to make a much, much better one soon. I say that because for all my life I have used a tractor to plow snow, and just this year realized I was doing it backwards. That was because this year I used my homemade grader to plow snow out of my driveway and logging roads, and it cut my plowing time to less then half. I could easily shave more time off if my grader blade was wider, and more purpose built.
There is nothing like putting the tractor in 7th gear (out of 8) and watching the snow just roll off the moldboard. I have to put my tractor in the snow before plowing it, but we do not get big snowstorms like we used to. Up to about a foot of snow, the grader blade works better and faster.
Now that I am using my grader blade both summer and winter though, it means I can fabricate one from the ground up and justify the cost and time to build it.
/ Grader/Scraper Build #16
You need a tool cart.
My gut feel after looking at the start of the tine bar and posting here that 8 foot is just too big for my tractor.
Go big or go home... well, I am already home! So there!
I cut a foot off each end to make her 6 ft.
Looks much more manageable for my little Agco ST34 now. :thumbsup:
Laid out the side plate attachment locations
Tacked up the side plates temporarily to give the ability to mock up the blade installation and support cross members.
Plan is to attach the cutting blade inside the side plate in a bolted adjustable configuration (ability to raise and lower the cutting blade level)
I will need to drill mounting holes in the side plates to bolt the blade configuration, when I get that measured and welded up I will then cut the side plate tacks, remove them and drill the blade mounts.
/ Grader/Scraper Build #18
Looking great so far! I think you made the right decision to cut it down to 6 ft.
/ Grader/Scraper Build #19
Looking good!!!
I would suggest that your runners be placed so the front "turn up" goes all the way up to the top of the angle cut on your side plates. You need enough "ramp" to lift the blade over an obstacle rather than it trying to cut in.
Looking good!!!
Richard, thanks for the suggestion.
Yes, that is the original plan, the runners are just tack welded in place to give me the correct height to mount the cutting blade. I plan to wrap both sides around with that 1/4" strap.
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2027 . 500k BTU Wellhead Heater (A67714)
2027 . 500k BTU...
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2004 INTERNATIONAL 4300 4X2 S/A  UTILITY BODY (A66091)
2004 INTERNATIONAL...
