Grader/Scraper Build
   / Grader/Scraper Build #1
redheelerdog
The Sticks of Montana
1944 Farmall M 2007 AGCO ST34
Here's the beginnings of a grader scraper modeled after EA's Land Shark. That thing is so awesome, when I saw the pics and vids I said to myself, "****, I need to build one of those!" - I could buy one, but where I am located in the sticks of Montana freight shipping is a hassle. But the biggest reason for building one is, I love building things, keeps my mind and hands active! Props go out to Everything Attachments for such an awesome design.
I have about an 1/8th of mile of dirt road I need to work, it's all flat and easy to work. Snow and winter get's it puddled up and it needs a re-doin a couple times a year, probably do some of the neighbors driveways too, I know they would appreciate it.
I had the side plates sheared at the steel place, also bought some angle and strap.
I bought an 8' cutting edge (plan is only one cutting edge - maybe add a second later) and some scarifiers with pins.
I had some left over 4" heavy duty box tube (this stuff is expensive) from a welding table I built last year.
Walleren' the holes out is a chore, not too bad though. After the 12th one I got darn good at it, lol.
Tweaked the holes with some weld metal to make the tines even. Only one was off about a quarter inch.
Added pin clips
Setting on the ground it came to me, Dang, I'm going to need a bigger tractor! LOL - Oh well, go big or go home!
   / Grader/Scraper Build #3
This is my DIY landplane,, and the tractor that pulls it,, it uses 7 foot cutting edges,,
I did hook it to my JD 4105 (41HP),, the 7 foot landplane was WAY too big for it,,,
   / Grader/Scraper Build #4
Gonna need a bigger tractor for eight ft. Built my land plane with two blades at six ft, My Massey 1742 will stop fwd motion if I let it fill up. I have a hydraulic gate on the back to limit material flowing out. Was playing out in a pasture building a dirt bike track in the summer.
   / Grader/Scraper Build #5
Added pin clips
Keep posting your progress / pictures. I am currently gathering the metal to build one also. I was not planning on the cutting teeth though. I just picked up two 8 ft cutting edges. I am only planning on making it 6 ft wide
Hmmm... maybe I will cut the ends off and make it 6 foot wide? My gut feel is that will be a better way to go with my Agco ST34. My road is flat with no grade.
   / Grader/Scraper Build #8
When I built mine, I purchased a couple of nos blades. One serrated and the other straight. Bad idea. The serrated one will pick up a rock and totally screw with the finish on the drive, leaving a gouge till I remove the culprit with a hammer. Have to keep an eye on it constantly. Back up cam would come in so handy.
   / Grader/Scraper Build #9
Nice ! We built a 3 meter wide drag from I beams years ago together with neighbours. I can still pick it up if i need it, but im thinking of making a 2 meter wide version to do some work in gardens with my 3011.
   / Grader/Scraper Build #10
Very nice work !! Keep the pics coming. Just for reference mine has two blades and weighs about 650 lbs. It is 5' wide and I pull it with a 30 hp 4WD L3010. When it is running near full it is all my tractor wants. With a single blade I could go wider. You will like the job it does .....
gg
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2014 Ford Escape SE (A56859)
2014 Ford Escape...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2017 Chevrolet Silverado Pickup Truck (A55973)
2017 Chevrolet...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
