My pole barn...a solo affair
   / My pole barn...a solo affair
The door rail cover came in and with little effort, installed. 3-7-20 Door Track Cover Installed.jpg Just need to pressure wash the rest of the barn now.:eek:
Then tippy toeing on the step ladder until the tin over the track was installed. I'll installed the far end piece after the door is installed. I had to pull the door off to installed the door top end J trim.3-7-20 Tin Almost All Up.jpg
hugs, Brandi
   / My pole barn...a solo affair #332
Lookin good!
Is your door track a single track. Doors butt together?
   / My pole barn...a solo affair #333
Looks like it's always been enclosed. Nice work!!
Lookin good!
It is a single track with the doors butting together. I plan on adding 8 (maybe 10) feet of track on the other end. With 8 feet, only 4 foot of the openings will be blocked by the door.
hugs, Brandi
I also installed a concrete pad in front of the walk-thru-door. 3-8-20 Fritz Looks At The Concrete Porch.jpg3-8-20 Concrete Porch Installed.jpg I made it in 1994 and both kids have their handprints in it. Truly special! It has been moved 3 times and thankfully the wire embedded keeps it together. Fritz just had to be in the photo.
hugs, Brandi
Oh yeah. Saturday I reinstalled my shingle on the walk-thru-door.3-7-20 Airplane Mechanic Sign.jpg
hugs, Brandi
   / My pole barn...a solo affair #338
Awesome, so all you need now is a landing strip. LOL
   / My pole barn...a solo affair #339
I added doors to the front of my open sided machine shed a few years ago. Used single track for two doors. I added track out past the ends of the shed so the doors could open that way and have the whole side of the shed open at the same time. I'm not sure that was such a good idea. When open, the doors are susceptible to wind.
I suppose double track would be the most logical in your case. But, I'd have done it just like you did. Using what you already have.
I've got several squares of concrete that I have repurposed over the years. Using a couple right now as a temporary sidewalk to our new house until we get an apron poured this Spring.
Unfortunately I don't have any with my kids handprints. That is very cool!!!!
Nice work and thanks for the updates!!!
Thanks!
No landing strip suits me just fine, as I have only worked airliners the last 35 years. Don't want any "work" :eek:anywhere near my home.
hugs, Brandi
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
CID 72" Skidloader Heavy Duty Mower (A50775)
CID 72" Skidloader...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
New 4-12-16.5 Forerunner Skidloader Tires & Rims (A50775)
New 4-12-16.5...
