Warranty issue dispute with Kubota - Advice anyone
   / Warranty issue dispute with Kubota - Advice anyone #31
When the engine gets hot it expels any excess fluid thru this tube to the reservoir. After you shutoff the engine and it cools it sucks the fluid back into the radiator. Great setup. When everything is working you never have to top off the radiator. It reuses what would normally be spit onto the ground.
If the tube has a hole it will expel the heated fluid onto the ground. When the engine cools it cannot create a vacuum and refill from the reservoir. It only sucks air thru the hole. Eventually an overheat situation will occur. Very possible that the gauge won't reflect this.
You got it so right, only 2 hoses and one small tube hooked to the radiator.
   / Warranty issue dispute with Kubota - Advice anyone #32
Most of my vehicles and equipment say not to remove the radiator cap. The radiator needs to be completely full for the draw back from the reservoir to work. Kubota says to check the reservoir; they do not say to remove the radiator cap on any of my 5 Kubotas. As pointed out in the copy of a manual posted earlier, Kubota, in all of my manuals, says only to remove the cap if the level is below the low and then to do it only when it is safely cold filling the radiator completely. So now it comes to the leaky overflow hose (I assume that is the leak because an air leak in it will prevent draw back). What caused this leak? Could it have been there from the start? Mine are so well covered it’s difficult to see how they could be damaged but I don’t have the particular model involved. Also, the sender is not in the head - it is in the block so a lot of fluid must be lost before it becomes uncovered. My experience is overheating will occur long before the sensor is dry. By the way, I have a GR2120 sensor handy because I found the sensor on mine defective. The new one will change when heated with my heat shrink gun. Once again not the same as the OP’s tractor. But was the leaky tube the lower radiator hose? Now we are talking something more prone to damage, sudden coolant dump, and engine failure.
   / Warranty issue dispute with Kubota - Advice anyone #33
If y'all think they work that's cool, but I wouldn't trust it.
   / Warranty issue dispute with Kubota - Advice anyone #34
...What caused this leak? Could it have been there from the start? Mine are so well covered it’s difficult to see how they could be damaged but I don’t have the particular model involved. Also, the sender is not in the head - it is in the block so a lot of fluid must be lost before it becomes uncovered. My experience is overheating will occur long before the sensor is dry. By the way, I have a GR2120 sensor handy because I found the sensor on mine defective. The new one will change when heated with my heat shrink gun. Once again not the same as the OP’s tractor. But was the leaky tube the lower radiator hose? Now we are talking something more prone to damage, sudden coolant dump, and engine failure.
The engine is locked up. Why do I wonder if the OP missed seeing an idiot light or temperature gauge?
   / Warranty issue dispute with Kubota - Advice anyone #35
The OP should have noticed the lack of reading on the temp guage during warm-up and early operation minutes.
   / Warranty issue dispute with Kubota - Advice anyone #38
if it turns out you have fix it yourself, and engine just froze and didn't throw a rod maybe remove the head and squirt some brake fluid in cylinders that might break it free,, have done it with car engines then use wrench to turn it over by hand
   / Warranty issue dispute with Kubota - Advice anyone #39
I've had a couple of pickups with bad radiators over the years and as the water level drops the gauge never moves. That's one disadvantage of electric sending units vs sensors.
   / Warranty issue dispute with Kubota - Advice anyone #40
I don't know about tractor temp gauges but modern automotive ones are usually three state idiot lights disguised as gauges. They indicate low, normal, and high. The "normal" state often has a large range. Making the gauge move gradually like a real gauge would is part of the illusion.
PREDATOR 8750 GAS POWERED GENERATOR (A58374)
PREDATOR 8750 GAS...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2005 JOHN DEERE 317 SKID STEER (A52709)
2005 JOHN DEERE...
2019 GALYEAN...
