Warranty issue dispute with Kubota - Advice anyone
   / Warranty issue dispute with Kubota - Advice anyone #11
What does the owners manual tell you to do? If it says to check the overflow bottle not the radiator you might have a case. The owners manual is technically a legal document telling you how to use and maintain your machine properly, so if you followed it, then you need to point that out to them. If they are telling you that you needed to do something that was not in the manual, then how would you know to do that? The best way to make your case is to show you did exactly what they told you to do.
It sounds like anyone with a Kubota needs to move their temp sensor to the engine not the radiator. Never seen one on a radiator.
   / Warranty issue dispute with Kubota - Advice anyone #12
The sensor is not in the radiator.
If the cooling system is compromised by a hole in a tube or hose caused by a foreign object the system cannot create negative pressure and draw coolant from the tank to the radiator. Even if it could, the pint of coolant would quickly join the rest of the contents of the system on the ground.
Any warranty claim related to a foreign object puncturing a cooling system component is a non-starter.
   / Warranty issue dispute with Kubota - Advice anyone #13
Where is the tube that leaked located ? Was it damaged from use or a manufacture defect ? I don't always take off the radiator cap to check for fluid, but always check the overflow tank. I would think you should have noticed fluid on the ground or the smell of leaking anti-freeze. I would be more inclined to know why that tube leaked then go from there. That is the problem.
   / Warranty issue dispute with Kubota - Advice anyone #14
^^^ Good point
Also agree with Rick -if there is damage from a stick or similar , it is a non starter
Radiator coolant level senders are Not real common as a factory feature
But some auto manufacturers did include a Radiator water level sender unit.
I am sure it saved a few engines from damage.
Mazda cars equipped with Rotary engines all had this sender in the radiator afaik
I have considered adding a bung to the radiator and installing 1
not to pricey at around $60 If anyone wants to add 1
https://www.ebay.com/p/1711255745?iid=230374507911
Sorry this happened to the OP and I realize anyone that buys a New tractor would think it is crazy to modify a new radiator and void the manufacturers warranty.
Just wanted to point out that there is a sender available for this situation /scenario
   / Warranty issue dispute with Kubota - Advice anyone #15
Something seems amiss - Per the service manual for that tractor,
coolant temp sensor is on side of block - OP should have gotten
high gauge / alarms
   / Warranty issue dispute with Kubota - Advice anyone #17
high gauge / alarms
Sorry, that is not always true.
Once the coolant level in the block/head begins to drop the sender is just exposed to air or vacuum and since air does not transfer heat near as well/fast as a liquid does it is very possible for a gauge to stay in the cold or normal range even though the engine is overheating.
In addition This has caused a few engines (not pointing at Kubota here) to overheat the head in the area of the exhaust valve seat allowing it ( pressed in seat ) to drop and result in destruction of the engine.
   / Warranty issue dispute with Kubota - Advice anyone #18
A coolant temp sensor will not read air, it must be in contact with liquid for an adequate reading. Just about every water cooled engine uses this system, including cars, tractors, heavy equipment etc.
I would have to side with the manufacturer, its unfortunate this happened to you but it sounds like the system was functional and you missed the leak.
If it was a large leak I would imagine you have seen/smelled it, if it was a small leak it should have given you enough time to catch the low level.
Ultimately its the operators responsibility to do regular maintenance checks including fluid levels and leaks.
It is a pretty rough situation to have happen but it doesn't sound like it was caused by something Kubota did.
I'm going to have to agree.
   / Warranty issue dispute with Kubota - Advice anyone #19
Is it fair that they are denying warranty? Probably not but I would say they are not obligated for your problem unless you can prove what ever caused the leak was a defect.
   / Warranty issue dispute with Kubota - Advice anyone #20
I think you're on to something.
The manual I found on line, under the "Daily Check" section, says: :
1. Check to see that the coolant level is between the
"FULL" and "LOW" marks of recovery tank.
2. When the coolant level drops due to evaporation, add
soft water only up to the full level.
In case of leakage, add anti-freeze and soft water in
the specified mixing ratio up to the full level.
(See "Flushing Cooling System and Changing
Coolant" in "EVERY 2 YEARS" in "PERIODIC
SERVICE" section.)
3. When the coolant level is lower than "LOW" mark of
recovery tank, remove the radiator cap and check to
see that the coolant level is just below the port. If level
is low, add coolant.
2016 Ford F-350XL (A57148)
2016 Ford F-350XL...
2018 Cadillac Armbruster 70 IN Limo - Only 49K Miles - Luxury Transport, Clean, Well-Maintained (A56435)
2018 Cadillac...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
