Chains Wheel spacers?
/ Wheel spacers? #1
Win3855
Maine
Mahindra EMax 20
I have a eMax20 and may want or need to put tire chains on it. There is not very much clearance between tire and frame bolts as in 1/2 to 3/4 of inch. Any known spacers or ideas.
/ Wheel spacers? #2
I’d be inclined to look into front chains. But if you need spacers I’d contact BX Expanded.
/ Wheel spacers?
All very good ideas and suggestions. Thank you.
/ Wheel spacers? #6
Glad you brought this up, I hadn't thought to check clearance before ordering rear chains :rolleyes:
My 1815 doesn't appear to have this problem, lots of room front of tire to frame and about 1 1/4" rear of tire to 3-point turnbuckle.
I have ordered these ATV chains ATV Twist Link Tire Chain Diamond Studded - Part no. ATV3DS they seem to fit your tire size.
They appear to fit the tire in the picture very snug, could be a lot different on an industrial tractor tire though.
Hope this helps?
/ Wheel spacers? #7
View attachment 643660 View attachment 643661
Hope this helps?
Thats not all that much clearance, sometimes the tire chain connector will take or need more clearance room depending on the connector and then if the chains get loose that might start hitting parts of tractor, that bang bang sound of chains hitting something is not a good sound to have. But there are usually some ways of making things work...........
/ Wheel spacers? #8
I bought 1.5" rear wheel spacers for an emax20 with industrial tires from motorsport-tech.com for the same reason and are happy with them. 1.5" is pushing the limit for mower deck clearance, I had to adjust the deck height so it wouldn't rub when the deck is fully raised. It just barely rubbed so yours may be slightly better or worse. I keep the spacers on all year. It does seem to make the tractor feel more stable when mowing side hills and using the loader. I have a pretty good hill to plow on a gravel driveway and use the diamond style chains with v-bars. It makes a huge difference, especially when it is icy. I use standard chains on the front too, helps with the steering.
/ Wheel spacers? #9
When we purchase Kubota had the dealer put the spacer on,plenty room for the ice chains.
2019 HINO 258A (A60736)
2019 HINO 258A...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2 new 8'' Pallet fork extensions (A61567)
2 new 8'' Pallet...
167 (A52708)
167 (A52708)
