Disassembling a small house
/ Disassembling a small house #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
I have a project to take down a small house. The catch is that it is 42 inches -- yes inches -- from the property line and the other side of the line is national park land. The National Park Service says I can't enter their property for the purpose of doing work, and I can't injure any trees on their side of the line. So any kind of machinery is ruled out, I think I have to disassemble the house by hand. It's not a big house, just a story and a half and the roof has about a 4 in 12 roof that is easy to walk.
My plan is just to do it in the reverse order that it was built. Work on the inside first, strip out all of the fixtures, then drywall and tile and floor coverings. Then take the roof off and the rafters. From there brace all the exterior walls, and cut through the top and bottom plates to cut them into manageable sections and pull them onto the floor, and then break them up. Once the second floor walls are down I'll take out the floor, and then repeat for the first floor.
Any tips, warnings or other thoughts?
If you're wondering how it got built so close to the line, the house was built before the park was created. The Park Service bought the land and the owner sold right up to the house.
/ Disassembling a small house #2
It would be bad of it caught on fire in the next lightning storm. If you don’t like that option I think a good operator on a trackhoe could pull it off.
/ Disassembling a small house #3
Someone who is good with an excavator shouldn't have any problem putting that house into a dumpster in a day or two without needing to enter their property.
Aaron Z
I don't think I'm going to be able to have an excavator come in. I'm not allowed to operate in the root zone of any of the Park Service trees. I don't see any way of approaching the house without crossing at least one tree.
Ordinarily, the law is that if a neighbor's tree crosses the line onto your property, you can do whatever you want with the part that's on your land. The law is different with national parks. They own the whole tree, you can't do anything to it. The fines for damaging their trees can be tens of thousands of dollars.
/ Disassembling a small house #5
I would talk to the park service. They need to cut you some slack on a house 42" from their land that I'm sure they want to see removed. A 100 hp skid steer or track hoe will take that house down in a day.
/ Disassembling a small house #6
^^ Wow, I didn't know that! I've seen other houses disassembled just as you described. Takes awhile, but you'll have some reclaimed materials that you wouldn't have if you used an excavator.
/ Disassembling a small house #7
What many will do is lay some 3 inch timbers on the soil to run their tracks on and that way they avoid damaging the soil and vegetation.
Even grass will survive as usually a demo is a short term thing.
Heck nearby they have been running all sorts of equipment on a tennis court using sheets of plywood as protection.
Why do you have to take it down? Just curious.
The owner wants to build a new, bigger house. I don't want to reveal the location, but it's a place with a notable view. There is a strip of private homes along the park. The owner paid about $1.5 million for the house and will probably pay another million to build a new one, and it will be one of the more modest houses. The rich people who own those houses have chronically encroached on parkland, to the point where the Park Service has gotten tough and is now enforcing zero tolerance. In order to get a building permit the owner will have to submit a "tree preservation plan" and probably post a six-figure bond. The tree plan will likely call for silt fence around the perimeter of the property and a foot of wood chips -- and no vehicles except on the driveway. The new house will be moved back from the property line, and where it doesn't overlap the existing footprint it will be on helical piles. There will be almost no excavation and what there is will be done by hand. In this context $20,000 or $30,000 to disassemble the house by hand isn't a problem.
Before you get upset about the heavy hand of government, understand that the buyer knowingly and willingly agreed to these conditions.
/ Disassembling a small house #10
I'd like to see a picture. It seems to me you could collapse the roof into the structure and them pull it away from the park side to buckle the walls.
/ Disassembling a small house #11
Back when I wore a younger man's clothes, I tore down 4 houses. I did it for the lumber.
Sounds like you are getting paid to do it?
Your plan of attack is logical. Buildings closely set next to other buildings are torn down daily without encroachment.
I agree that the owner knew what he was buying and the hassles involved. Start wrecking. :)
/ Disassembling a small house #12
Step #1 is to check Rhode Island laws relating to asbestos / lead abatement.
In Oregon, one can add about $30,000.00 to the price of building a home if they have to demolish an old house.
If you try to haul anything from a demolition to the dump they stop you in your tracks.
You're a better man than I. I just don't see a lot of lumber worth saving, what I'd end up with is a bunch of odd lengths full of nails.
Not getting paid, just helping out.
/ Disassembling a small house #14
Is there not room on any of the 4 sides to drive an excavator on? If not how are you getting equipment and materials on site to build?
/ Disassembling a small house #15
Then I would be highly concerned. I would want the owner to file all the proper paperwork including whatever bond coverage is required. Might even go so far as drawing up a simple stubby pencil signed agreement outlining liability. All this based on your comments of how the Park Service is acting.
Just helping out can become very expensive if things go bad.
/ Disassembling a small house #16
Someone here had a trailer house unhook and slide in a ditch upright but really warped. Unmovable. The owner was given time to move it but before he could move it , it burned up, surprisingly. Then he could use a FEL bucket and dump trailer. Problem solved.
/ Disassembling a small house #17
Unless you are being paid 6 figures, or more,, let the millionaire figure this out,, DO NOT use advise from a tractor forum,,
YOU could be in line to pay BIG fines,, even if you do not get paid,,,
Walk away, even if it is a relative,, do not even answer a question,,, unless, of course,, you do not mind paying the fines,,,
/ Disassembling a small house #19
Run Forrest, Run from the forest. Run far. Run fast. Do not pass Go. Do not look back. Let Owner BigBuxx hire a bonded contractor.
Why can't you just say what you feel???? ;)
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A65563)
2011 Ford F-350...
Aproximately 72' of Steel Catwalk (A62679)
Aproximately 72'...
Grain Bin Spreader (A65640)
Grain Bin Spreader...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
