Brush Grapple
/ Brush Grapple #21
I have one I built a couple years ago I would post pics but can't figure out how to
So,,,, I click on "go advanced" below.
Then I click on the blue "A" in the top row of icons, far left
Then I place my cursor where I want the pic to appear
Then I click on the square picture with four black dots at the corners, second row of icons, fourth from right end
Then I follow the directions in the newly opened window.
Once the pic is displayed in thumbnail size I decide what size I want it to appear
If I want it bigger I double click on the pic and select a size from the newly opened window
Bingo pic appears in whatever size I chose
/ Brush Grapple #22
I'm trying this. Just finished it. As OVRSZD said, I might use it for bigger things than it was built for. I'm hoping it works for me though.
Your cylinders will destroy the angle iron that the top ends of them are fastened to.
I like your concept. But it has to be overwhelmingly strong at the cylinder point and at the hinge point.
/ Brush Grapple #23
I didn’t want to be the first one to be Debbie downer again but yea there’s numerous wear spots in that design. I doubt the angle iron teeth are strong enough and I give the lids close to zero chance of surviving.
/ Brush Grapple #24
I was thinking the top pin would be my weak link. First attachment made. Still learning. Not much cost into the metal. All scrap so far.
/ Brush Grapple
I'm not sure what angle iron you are talking about. I used tubing, flat stock. and one piece of c-channel for the mounting plate. 1/2 inch solid stock is inside the cylinder mounts to prevent deforming and to not have to drill through 1" solid steel at 1" holes.
/ Brush Grapple #26
I think he was talking about my version. Sorry about that.
/ Brush Grapple #27
This one is my Solesbee’s.
It has seen better days & they were much before me as I bought it used. Even so it has been ok, but on Utility tractors the short bottoms are more operator friendly.
An EA Wicked as big as they will make it will be my next Grapple.
Dad ran a full service fan shop for over 30 years & we still have all his equipment & our abilities, including iron workers & big saws, but I’m buying a new Grapple when the time comes because my time is more limited at this point.
/ Brush Grapple #28
After looking at the prices and heavy weight of brush grapples, I decided to make one that slides onto a quick attach plate just like pallet forks. The entire cost with disposables is still under $300. The weight is still light enough to not effect the lift capacity of a smaller tractor. It can also scale up to two grapples for one on each side of the frame.
Update please. How is it doing?
/ Brush Grapple
Grapple works decent for larger piles. Smaller piles fall through as expected. The only problem I had with it was getting my woman to stop playing with it so I could check the keeper pins.
I need to add another mounting point lower on the vertical mount. This will take care of the smaller piles.
/ Brush Grapple #31
/ Brush Grapple #33
Yeah, I would like to see that too. It seems like a nice option for those of us with older machines that dont want to do a full 3rd function upgrade. I also like that it is button activated instead of splitting a function, so you can curl and close the grapple at the same time.
/ Brush Grapple #34
It is a prototype!
Prototypes are rarely satisfactory products!
/ Brush Grapple #35
Looks like an interesting approach. I've found that the more you use a grapple, the more abused they become. If you remember to take it slow, not try to do too much, and be extra careful, this might work for you. If not, version 2 should be even more interesting.
/ Brush Grapple #36
Yeah but Eddie, I can make a couple less trips to the pile if I take a bigger load!!! :)
/ Brush Grapple
I think a dedicated brush grapple for round two will be designed for more abuse. Possible with crunch and compact in mind for grabbing piles that are unwieldy.
/ Brush Grapple #38
Those of us with Grapple use experience knew you would get to that point quickly.
I don't know of anyone that doesn't wish their Grapple would do just a little more. :)
/ Brush Grapple
The first grapple fits it's design criteria. Lightweight to not impact overall lift capacity. Easy to install or remove. Modular to fit neighbors pallet forks. The hydraulic cylinder is easily moved to a larger grapple.
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
New/Unused 20x30 All Steel Carport (A61166)
New/Unused 20x30...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
2003 Badger 1085D Wheeled Excavator (A61166)
2003 Badger 1085D...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
