Ford 4000 Questions
/ Ford 4000 Questions #1
TBigLug
Stockbridge, MI
John Deere 401C
1964 Ford 4000 (841), 4 sp. Couple questions.
1. What is the procedure for adjusting the brakes? They work but barely and only right before the pedal hits the floor.
2. What could cause a no first gear issue? Tractor was like this when I bought it. It doesn't grind or anything, shifts into the slot like a normal gear. Let off the clutch, nothing there. I don't have a concrete floor so I don't think I can split the tractor and get it back together. Anyone ever seen a problem like this or have a diagram of the transmission? I'm hoping it may be a busted pin or some such.
Thanks for the help.
/ Ford 4000 Questions #2
Go to CNH parts online website. They have great pictorial parts diagrams showing all parts involved.
In this case I looked for the brake linkage parts to figure out how to adjust the brakes.
See Part # 27 & 28. They show the linkage rod and clevis that are adjustable to get "good pedal".
I have no clue in regards to the trans problem. But again this website may offer pictorials of the trans setup that might give you a clue.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
/ Ford 4000 Questions #3
Adjust the brakes through a slot in each backing plate via an adjuster with a star wheel as you would a typical drum & shoe brake. Use the external rod and clevis adjustments to balance the pedals after adjusting the star wheel.
/ Ford 4000 Questions #4
Good stuff Rick!!!!
I was so wrapped up in the linkage adjustment that I forgot to send him there first.
Again, on the CNH parts website there's a very good picture of the wheel brake assembly, including the adjusters.
Awesome, I ended up getting the brakes adjusted. No rod and clevis for my pedals, just bolted to a shaft. I'll look into the parts diagrams for trans ideas next. Thanks.
/ Ford 4000 Questions #6
I first remove the clevispin from the brakelinks. Then adjust the brakes to lock wheels then unscrew starnut till wheels come loose.
Then I adjust that clevis and rods til pedals is equal.
