Forum for air cooled diesel engines and clones
   / Forum for air cooled diesel engines and clones #441
Hey All,
So, I did removed the muffler on my 186F due to it being restrictive at the outlet at the head. I welded up a pipe and stuck it on there. Runs better now but its deafening. I need some sort of a muffler.
Anyone ever replace a muffler with something other than OEM?
Just order something off eBay or go to tractor supply. A small muffler off like a international cub or some small zt lawnmower should work.
   / Forum for air cooled diesel engines and clones #442
Thats what I was thinking but then again thinking restriction. Just looking for ideas....
   / Forum for air cooled diesel engines and clones #443
Hello too all !
I am new here and from Sweden.
I have a Chines 186f with electric starter
and a 230/400V 3-phase generator. It has a remote
start that has faild. (yes, new battery in sender)
I found a new used sender/reciver but it not works as suppose to.
First I would be happy to find a electrical drawing for my motor/generator, and a source where to buy a new remote that fits my generator.
The two recivers looks different inside, I will try to put up some
pics. It is the reciver with 4 relays inline that worked fine until it just died....
I have to be back with pictures later.
I hope that you understand my old school English !��
   / Forum for air cooled diesel engines and clones #444
Here is pictures of the recivers and the generator ! 20190221_133539.jpg20190305_185152.jpg
   / Forum for air cooled diesel engines and clones #446
Hey Guys,
I've got a Titan 7500 D w/ the 186. Had a couple of questions that you might be able to help with:
1: Any suggestions on how to firmly pin down the engine and it's variants like A, AF, FE, etc.
2: The gen head failed after about 125 hours. (Exciter coil burned up.) The output shaft taper on the motor is a bit of an oddball and i can't seem to find a compatible gen head. (Most everything here is either J609 A -or- J609 B.) This one might be more accurately described as Chinese " Electrical Taper " ? Any leads on a 6KW gen head ?
Thanks
   / Forum for air cooled diesel engines and clones #447
Guys, I'm trying to replace the governor oil seal on my 186F. I took the speed control off to access it. There is a pin that looks like it needs to be popped out. The pin though is not budging. I've been hitting it with a hammer and punch but I do not want to hit it so hard I damage the fork. Any ideas/suggestions?... I am taking this off correctly right?
Thanks
Randy B
Looks like 1 pin secures it.
Support the arm as you tap the pin out to prevent damage.
   / Forum for air cooled diesel engines and clones #449
Thanks, I looked up the pin # and it is a tapered pin so that helps a lot. I'll get back to it in another day or too.
   / Forum for air cooled diesel engines and clones #450
While I ponder how to get my stuck taper pin out... Someone school me on the "Start of Delivery" method for timing a diesel.
Thanks,
Randy
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
2009 BMW 335i Coupe (A55853)
2009 BMW 335i...
20711 (A50323)
20711 (A50323)
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
