Cut the Cord and switched to an Antenna for TV
/ Cut the Cord and switched to an Antenna for TV #71
ROKU can also run your free antenna stations via TABLO. I use ROKU to broadcast wirelessly to all the TVs in the house. So all of the services come into one spot and the WiFi takes it everywhere from there. Really nice when you change around the furniture in the house and just need to plug the TV into power. Or summertime I move a TV onto the deck and watch it out there.
The ROKU streaming stick + has the best wireless range, I would go with it for wireless TVs
/ Cut the Cord and switched to an Antenna for TV #72
Did the same as eddie starting this week.28 years ago when we built our house we put up a 30 ft.antenna & tower we let it go for prime star/dish tv.This coming Friday we are having the old antenna rotor removed(still have the 30 ft tower in place) and installing a new Winegard model 8200 antenna & channel master rotor model 9521D.Tired of the high costs.
/ Cut the Cord and switched to an Antenna for TV #73
Maybe a little late in mentioning (or asking) this, but why are you choosing an 8200 model? I don't think there are any channels 2-6 in your region. The Winegard HD7698P would be a better choice. I also think a ~20 pound antenna with a 14 foot boom is going to give that rotor a premature death. A CDE/Hy-gain bell type would be a lot stronger.
I do have channel 2 Detroit and channel 6 Lansing.Going with the antenna & rotor my installer has.Looked at a few reviews and the 8200A was rated better than the 7698P.
/ Cut the Cord and switched to an Antenna for TV #74
all you can get is 13 commercial laden channels though!. and the hours that something worthwhile is on is very limited, and filled with commercials!. no guide or DVR either.. you have to watch what's on when it's on, no recording!..
There's no such thing as "those 13 channels" any more. There are gobs of various channels through the air. Best antenna I've found so far is a flat one that RCA makes. Looks like a black iPad sitting in the window, flat. We get 16.1, 19.1, 19.2, 19.4, 27.1, 27.2, 29.1, 29.2, 29.3, 31.1, 31.2, 31.3, 31.4, 31.5, 31.6, 41.1, 41.2, 41.3, 41.4, 41.5 and occasionally can pick up some in the 50s the other direction.
Have Roku for ESPN stuff, free movies on Roku and Tubi and occasionally some stuff on TBS, etc.
Ralph
/ Cut the Cord and switched to an Antenna for TV #75
I'm thinking about getting a LG soundbar for better sound. My current amplifier is still very nice, but it's beyond me to figure out how to get sound to work from it with the cable from the antenna going straight to the TV
Sound? What sound? I gotta have the captions. Otherwise, I'm clueless to follow dialog.
Ralph
/ Cut the Cord and switched to an Antenna for TV #76
I'm not familiar with HULU. Does that use data through the phone? If so, I don't have an "unlimited" plan on my phone, so HULU would probably not work.
I use SlingTV. Now, Hulu has a better deal to get ESPN, etc. These both are on the Roku stick. Lately, Disney is bundling Hulu and its stuff together. Not sure about whether ESPN is in the Disney deal.
Ralph
/ Cut the Cord and switched to an Antenna for TV #78
Most folks don't realize that the TV channels advertised are not the actual channels they are on.
In this case, WJBK in Detroit (ch. 2) is actually on channel 7.
WLNS Lansing (ch 6) is actually on channel 25.
If I were in your shoes, I would forget the rotor and install a Wingard HD7694P or HD7698P with or without a preamp and point it to Lansing. You will have all your network coverage; CBS, NBC, ABC, Fox, CW and PBS. None of the other locations will give you anything different. If you want some of the special sub channels like Ion and MeTV, you'll have to search them out as to where they are.
Your 8200 is 14 feet long and 9 feet wide because it's made to include channels 2-6. The only VHF-Low channels around are 5 in Toledo (religious) and one in Kalamazoo (an independent). The two Wingards I mentioned are only about 4 feet wide because they don't have the big elements for 2-6 coverage. Also, the longer the main boom, the narrower will be the beam pattern. You may be happier with all the channels you get with your more expensive plan, but I don't think you'll like it in the long run. Remember too, stations over 50-60 miles distant will not have reliable reception.
Done deal already paid antenna company /installer last week.Install this coming Friday.Will let you know how I like it.Been 28 years since the last antenna.We live high on a hill maybe that will increase our signal..
/ Cut the Cord and switched to an Antenna for TV #79
^^^^ those are in good alignment, relatively speaking. Mine are not as far away but more spread out (about 110 degrees) and a fixed position flat 180 degree antenna on my chimney gets them all. Again, not as far away as those, but not close by any means plus an island to hop over.
To update this thread, we've found that a lot of the "free" channels that we where getting where timed for a month or two, and then they started locking programs. A show might have ten seasons, but we could only watch half of them, and then it went down to maybe two seasons out of ten.
My wife was getting us some paid for channels through her AT&T cell phone account, but it was limited to what was on at that time, and only about a dozen channels.
We looked at what was out there and decided to pay $20 a month for Philo. Welcome to Philo
This is kind of like cable or Dish in that you can watch a variety of channels, but it's also better because you can go to that channel and look up older shows and entire seasons. For example, I like that show called FantomWorks on Motor Trend. It's no longer on the air, but they still play old episodes. I can click on Motor Trend and bring up all their shows, then click on FantomWorks and pull up every episode. I like to state with Season 1, Episode 1 and just go through every episode of that season, and then do the same with the next season. My wife loves Who's line is it Anyway, so we're watching every episode, from season one to the end. We just started Season 3 and will watch one or two episodes before going to something else. This gives up so much variety to chose from depending on what we are in the mood for.
2017 Freightliner M2 106 T/A 26FT Reefer Box Truck (A59230)
2017 Freightliner...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59908)
2018 FREIGHTLINER...
2014 Top Hat Trailer (A60352)
2014 Top Hat...
2025 BrushFox HD-78STD 78in Hydraulic Rotary Brush Cutter Skid Steer Attachment (A59228)
2025 BrushFox...
