3 Point Not working 7305 Cub
/ 3 Point Not working 7305 Cub #1
brokenknee
South of Moose Lake MN
Was having trouble with my three point not going all the way down, this spring it stopped working all together. With winter coming on finally brought it to a repair shop about three weeks ago. He is not a Cub dealer, just an independent guy that works out of a shop.
I got the tractor back yesterday, when I asked what the problem was he said an allen screw had started to back out of the valve. This valve is inside the three point, He said he missed it the first time and had to open the three point case again. He said the first time he checked it with air and all seamed good, so he put it back together only to find it did not work.
Total cost for the repair and to have hydraulic fluid and filters changed was $508 and change. He did not charge me for having to go back in the second time as he said he should have caught it the first.
Just posting to give others an idea were to look if they have a similar problem and to give Ed at Fossten Ag repair kudos for staying with the problem.
/ 3 Point Not working 7305 Cub #2
Resurrecting this for ease of future searching
I have a 1999 Cub Cadet 7305, hydrostatic drive, 4WD, located in north central Massachusetts.
At the end of my first plowing pass on during last storm the 3 point hitch (with back blade I was using to plow) went down and stayed down. I unhooked and finished plowing with the front end loader but sadly the 3 point hitch is still out of commission. The raise/lower lever has no effect and I hear no sounds coming from the hitch when I move the lever.
I took a look at it today - here’s what I found.
* Raise/lower lever is connected and linkage is moving correctly. It rotates the valve that goes into the hitch housing.
* Hydraulic fluid is clean and correct level
* Hydrostatic transmission working well
* Rear PTO (located right below hitch) is operating correctly
* Front end loader is operating correctly
* Hitch flow control/speed knob is fully open
* All hose connections are clean and connected firmly
* No leaks
Is there anything else to try short of cracking open the internals? Failing that, is there anyone local to north central MA (preferably mobile/come to the house) you’ve used and could recommend?
Thanks!
Chris
/ 3 Point Not working 7305 Cub #3
Good morning,
I am experiencing the very same problem as the orginal poster. 3 point is stuck in the down position and will not raise. No noises coming from hydraulic system, contol lever between your legs can be left, right or in between, it has no effect on the inoperable 3 point. Short of tearing out the seat, fuel tank, and fenders to remove the valve bank, any ideas from all of you out there to troubleshoot this problem? All linkage is working as it should, 3 point just stopped working without any other symptoms.
/ 3 Point Not working 7305 Cub #4
Good morning,
On mine it turned out to be a small linkage in left side of 3PH unit. It popped off its post. Popped back on as temp fix but had to replace linkage in the end
/ 3 Point Not working 7305 Cub #5
Thanks, all linkage is connected. i have looked for the obvious already.
/ 3 Point Not working 7305 Cub #6
I would start at the hydraulic manifold block on the frame below engine,by hooking gauge to it you can see if you have pressure from pump and start to learn the hydraulics and the danger of 2100lbs of oil pressure.Without a manifold block you could end up tearing tractor down to the control valve inside transmission and do more damage than good,they are precision machined to control the high pressure hydraulics.
/ 3 Point Not working 7305 Cub #7
I also have a 7305 Cub Cadet that the 3 point stopped working while I was plowing snow. Initially I thought the linkage was fine, based on a quick visual inspection. I could lift the arms myself and they would lower with no resistance, and the loader bucket and PTO worked fine. I ended up pulling the seat and seat pan, and the shrouds that the levers pass through on each side of the seat. Here I could observe the linkage problem I was experiencing. The part number is MA-19642453AG0. The pin that connects the piece on the shaft to the 2-3 inch flat metal piece had sheared internally. Visually it was really not obvious at all until I watched the linkage actuate while moving the lever up and down. The price on that part is almost $200 which seems ridiculous to me so I plan to drill out and weld in a new pin. Hopefully that will work. See #18 in attached screenshot. Hopefully this helps someone!
/ 3 Point Not working 7305 Cub #8
Ooh, ooh, ooh, Mr. kotter, Mr. kotter, I got an answer......../end Horseshacks accent
Let me find the thread I started last summer about what sounds/looks like my solution to the same event your experiencing @lmoerer
/ 3 Point Not working 7305 Cub #9
Here's my link and the pics are on post #19
/ 3 Point Not working 7305 Cub #10
I'm not seeing a link, and I am definitely curious about what your findings were! Thank you for the follow up!
/ 3 Point Not working 7305 Cub #11
Okay, so I see in mobile format that once I "pasted" the link - that doesn't guarantee it stays when I click send......
So, 2nd attempt. In the search window you can put the following text in the search box - it is the subject title:
Default 3 point arms won't respond to control arm spontaniously today
NOW, I will try to cut-n-paste with the "www" part removed as I had seen someone else remark about having similar difficulty and so they switched the "www" for "qqq" and their link stayed in the posting on a different thread.. .
Qqq.tractorbynet.com/forums/hydraulics/414942-3-point-arms-wont-respond.html
Now, maybe this will work - this time?
/ 3 Point Not working 7305 Cub #12
That worked perfectly. It looks like your linkage failure was identical to mine. The parts I removed are identical to your parts in the last photo of the thread you linked. I tried posting a link to that exact image for context here but my post count is too low for posting links... Oh well.
Thanks for the help! Hopefully these posts will help out other 7000 series Cub owners and Mahindra 3015 owners wandering the web looking for help.
/ 3 Point Not working 7305 Cub #13
Yeah! Glad for both reasons. A) it worked for you to see & b) success in your solution too.
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A61165)
2021 Big Tex...
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61567)
Katolight...
UNUSED GIYI D-PDQ LAND LEVELER (A62130)
UNUSED GIYI D-PDQ...
Wooden Wagon Wheel Rocker (A61569)
Wooden Wagon Wheel...
2004 CATERPILLAR D5N XL HIGH TRACK CRAWLER DOZER (A62129)
2004 CATERPILLAR...
2011 John Deere 1770NT Planter (A63109)
2011 John Deere...
