L6060 vs Mx6000
/ L6060 vs Mx6000 #1
7879fordman
Gold Member
gillham arkansas
1969 massey 135 and a 2013 m7040hd 4x4 2013 L3800 HST 4x4
Looking at one or the other With cab. Had looked at them side by side at a dealer there things on both I do and dont like . Price quoted was $47,000 l6060 $40,000 mx6000 base options . Add ons for 3 rear remotes and 3rd function is the same . From what I read the l6060 has more 3pt lift and even more loader lift . Even though the mx6000 has a hair bigger loader . Is the l6060 really the better buy at $7000 more . Let's here thoughts . And some other pricing if yall got it on these models.
/ L6060 vs Mx6000 #2
The premium feature on Kubota 'Grand L' tractors is the HST+ transmission. Stall Guard is invaluable doing Loader work. Six closely spaced HST ranges is valuable in ground engagement tasks.
Unusually, Grand Ls come with two-part wheel rims when ordered with R4/industrial tires, so rear R4 wheels/tires can be configured with a wide stance during dealer assembly. If Loader work is a priority, a wide stance will greatly increase stability, allowing you to use the Loader more efficiently.
HST/PLUS VIDEO: YouTube
MX VS GRAND L: Kubota Grand L Series VS. Kubota MX Series - YouTube
As your profile includes a Kubota M7040, is 3pt lift an issue? The M7040 will be more stable under heavy 3pt load.
Like the M7040, Grand Ls have paired external hydraulic cylinders lifting the Lower Links.
MX6000, L6060 and M7040 all have a Category 2 Three Point Hitch.
/ L6060 vs Mx6000 #3
The two part, adjustable rear rims available with R-4 tires is one of the reasons that I bought my L6060 rather than the competing JD 4066R, which I preferred in some respects (especially EPTO). When specified with R-4 tires, the 4066R is available only with one piece, non-adjustable rear rims, which I cannot accept for multiple reasons.
SDT
SDT
The two part, adjustable rear rims available with R-4 tires is one of the reasons why I bought my L6060 rather than the competing JD 4066R which I preferred in some respects, especially the EPTO. JD supplies only one piece wheels/rims with R-4 tires on the 4066R, and this is unacceptable to me for multiple reasons.
Edit: Not sure why this post is duplicated.
SDT
/ L6060 vs Mx6000 #4
HST+ is the main reason I stayed Kubota after looking at a half dozen alternatives. I find some or most of the other premium features (auto throttle, cruise control, throttle advance button, etc.) over a economy L a bit gimmicky. But after 450 hours I'm more sold on the value of HST+ than when I was shopping. Generally you just leave it in medium range & shift on the fly with the high/low range lever. EVERY HST tranny from every OEM on tractors sucks for range shifts. The 2 speed on HST+ means you dont have to deal with the clunky unsynchronized 3 speed much.
/ L6060 vs Mx6000 #5
Whatever you decide on, keep in mind that it's Tier 4 final and Kubota has been having issues with their emissions systems. and... If you plan on keeping it a long time, the DPF is only good for 2500 regens and then has to be cleaned (typically 500 bucks) or replaced (1000+ bucks). and usually when they are at their 'end of life' cycle, sensors have to be renewed as well.
None of it is cheap. Saying that, all Tier 4 final engines all have the same issues, Kubota is having more it seems.. I will never buy a T4 final tractor.
/ L6060 vs Mx6000 #6
I actually havent seen that many issues with Kubota. Especially compared to Ford/Chevy/Ram on road going trucks. I havent paid to much attention to other tractors though. There are definitely issues with the extra (emissions) systems that weren't needed in the past. That's upsetting & frustrating, but the percentage of issues doesnt seem to be that high.
2,500 regens at 20 hours between regens is 50,000 hours. If it only goes half the time between regens & lasts half the number of regens stated that still double the hours I expect a CUT to last. That being said I've heard 5,000 hours might be more realistic, which is maybe half the way through a CUTs expected lifespan.
/ L6060 vs Mx6000 #7
I have been kicking tires too... I think the issue is what you are doing with it. The L6060 has more lift do to a heavier duty front axle. the L6060 weighs more.. Has the Glide shift (if I am not mistaken) vs HST. For me the MX is a better fit. Price... Matters to me, and the L6060 has a bigger foot print. I don't wasn't a bigger footprint than my MX4800. My MX regens about every 65 hours. I have has zero issues... The only reason that I was looking was the cab.
/ L6060 vs Mx6000 #8
I actually havent seen that many DPF issues with Kubota.
Neither have I.
The average homeowner uses a compact tractor 60 engine hours per year. Perhaps OP will use his tractor 100 hours per year. Projecting a conservative service life of 3,000b engine hours for DPF that equals 30 years of tractor use.
/ L6060 vs Mx6000 #9
Neither have I.
There ya go again,,,, being a realist..... ;)
/ L6060 vs Mx6000
Neither have I.
That probably about right 100-150 hours a year
/ L6060 vs Mx6000 #11
The B3350 had a ton of problems with the DPF system and is being replaced. But the systems on the L and Grand L models have been super reliable. Can't think of any problem reports here on TBN.
/ L6060 vs Mx6000 #12
The 3350 used a reformer which really isn't practical for a small displacement diesel engine.
/ L6060 vs Mx6000
Let's get back on tract and keep it l6060 or mx6000 for me and others that will be comparing the two against each other. Thanks .
/ L6060 vs Mx6000 #14
Neither have I.
Provided that along the way it don't have issues. That is the rub and once you exceed the federal mandated 5 year emission component warranty, it's all on your dime. I might add, none of it is cheap either.
/ L6060 vs Mx6000 #15
No glide shift on L6060, and wheelbase is different by only .2" (MX slightly longer). MX does have larger front tires.
SDT
/ L6060 vs Mx6000 #16
Get the L6060. It's the Cadillac of the tractor world. If you can afford it, don't conjure up reasons to get anything else. The lift capacity difference in not worth mentioning. Take a little less on your scoops. How often are you moving mountains of Earth? The hstc is divine. Stall guard is sweet. I moved 400 yards of top soil in an afternoon once with out even an attachment in the back for ballast. Full heaping scoops no problem. It's just overall so smooth and powerful.
/ L6060 vs Mx6000 #17
SDT
Odd, was about to call you out on the no GST, but I looked at the build site & that's correct. The L5460 & L6060 can only be speced with HST+. The L5060 can only be speced with a GST. L4760 with HST+ or a GST. The smaller Grands can be speced with HST+, GST or a fully synchronized manual. I thought all the Grands had the same tranny options.
Personally I think GST or Powershift type trannies are ideal for ag due to their efficiency. But HST is where it's at for the ease & precision of use for a CUT doing varied tasks.
/ L6060 vs Mx6000 #18
Messicks coming in hot with the comparison you want:
/ L6060 vs Mx6000
I'm leaning to the l6060. Some really sway me to the mx6000 other then price .
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
Metal Grain Racks (A60352)
Metal Grain Racks...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
7888SFL (A61567)
7888SFL (A61567)
2005 John Deere 210LE 84HP Loader Utility Tractor with Box Blade (A61567)
2005 John Deere...
2025 GIYI Hydraulic Backhoe Mini Skid Steer Attachment (A61567)
2025 GIYI...
