Comparison Cylinder vs cycle
/ Cylinder vs cycle #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Just for a curiosity, I was looking at specifications on Compact Tractors from the B2301 on up to the Grand L.
Under the engine specs, the Kubota site calls the engines....e.g. 4 cycle diesel in the bigger models .... versus a 4 cylinder in the smaller models.
What's with that?
/ Cylinder vs cycle #2
What's with that?
All modern diesel engines along with most gas engines are 4 cycle. Old Detroit diesels were 2 cycle, but are obselete & no longer produced due to emissions reasons. Similar story for cycle gas engines although there might still be some in use for lawn care equipment or power toys.
Everything else being equal, which is going to make more power. An engine that fires every 4 strokes/cycles or every 2? They had great power to weight ratios. But gas ones were always temperamental to keep running & all fuel types were pretty dirty by all emissions standards.
All modern engines have various numbers of pistons or cylinders & that has no relationship to being 2 or 4 stroke/cycle.
/ Cylinder vs cycle #3
I believe you'll find most if not all of the smaller current tractor engines have three cylinders - these will have three injectors and three glow plugs. The larger current engines, I'll say above a nominal forty horsepower may move up to four cylinders. Years ago Mitsubishi (and probably others) produced two and four cylinder four cycle diesel engines. I have one of the older four cylinder Mitsubishi engines. The four cylinder units seem a bit smoother than their three cylinder counterparts, the exhaust sounds different as well, but either will do the job.
/ Cylinder vs cycle
Thanks Fallon. But I thought the spec sheet would tell how many cylinders are in the larger HP engines, just like they tell in the lower HP models.....e.g. my B2650 has 3 cylinders versus the B3350 has 4 cylinders.
Cheers,
Mike
Dang it..........it did not read down far enough on the Kubota spec sheet...........further down it tells how many cylinders each engine has......Dah-h-h-
Sorry about that.
/ Cylinder vs cycle #5
I believe that EMD (or derivative) still manufactures 2 cycle diesel engines for locomotive and other applications but they are sadly no longer sold in the US.
SDT
/ Cylinder vs cycle #6
Another quick way to tell on Kubota's is if they list the engine model, the letter prefix tells the number if cylinders.
Z=2 cylinders
D=3 cylinders
V=4 cylinders
F=5 cylinders
I can't remember the 1 and 6 cylinder designations off the top of my head.
/ Cylinder vs cycle #7
Z=2 cylinders
D=3 cylinders
V=4 cylinders
F=5 cylinders
One thing I first liked about Kubota models names for their equipment made sense. Many other companies model numbers mean nothing other. Even more fun when a company uses the same model number again.
/ Cylinder vs cycle #8
Think you're seeing some translation problems. Most of them are 3 cylinder, and all are 4 cycle.
FYI, I just recently stuck a column of figures for the L in with the B2301 vs. JD 2025R comparison I made a long time ago. Big thing that sticks out is the weight of the L tractor. Be like running my Miata up and down the back hill or like my Tacoma with bush hog and FEL. Think a 25 hp engine would be deficient for that, particularly if I had a carryall in back full and full FEL. Probably would slide down the hill and not have the power to take it all up the hill.
Ralph
/ Cylinder vs cycle #9
Ralph
Hp isn't the whole story, compare the engine displacement and rpm that it makes the Hp. The lower the rpm at the rated Hp the higher torque.
Most semi's only have 350-450hp but will out pull a Vette with 600.
/ Cylinder vs cycle #10
Ralph
Few of the Kubotas have deficient HP to traction issues. My 40hp 6-7k lbs loaded L4060HSTC is a good match for ground engaging stuff. It could use more HP for roading on hills & running PTO impliments. You can get the same chassis in 35-60hp models. The higher HP machines generally only need that high HP to spin a big mower or other such PTO impliments.
Weight is what makes a tractor work. HP just defines how fast it can get the job done. With tractors low gearing you should never be limited on where you can go or what you can pull by HP. It's just a matter of traction & how slow you are willing to go.
2025 Western Star Dump Trucks 49X Truck, VIN # 5KKHBWDR7SLVH9248 (A61165)
2025 Western Star...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 48in...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
