Welder question...
/ Welder question...
I just have to shake my head....
Looking at three different welders.
So far, I'm three out of three where there is this "local" welder, yet all phone numbers are some other area code, not one out of them is local.
I know that's not conclusive as my OWN work phone number is a Nashville number, not a Knoxville number....
First one I emailed wanted my email to give me details.... had a phone number (that I had already called) and got a girl in St. Cloud MN
Kind of makes you want to just puke and go to store to buy new.
/ Welder question... #42
With most welders you can dial down the heat and do very light work, but if welder does not produce enough heat (amperage) being to small you can turn it up to the max and it still may not be enough so you may need a bigger welder (more amperage capable)......
Understand voltage and amperage in any welding is a matter of just producing enough heat (at arc/puddle) to create fusion bond...
SMAW is a term Stick Metal Arc Welding it's just a technique using a stick electrode usually flux coated to add filler material into fusion bond created by arc.
GMAW in MIG welding is Gas Metal Arc Welding, wire machine feeds a solid wire "electrode" from reel in machine and control flow of shield gas to around arc/puddle to protect it from oxygen till it solidifies...
FCAW in MIG welding is Flux Core Arc Welding, wire machine feeds a tubular wire "electrode" ( the encloses a flux core) from reel i machine and and "flux" creates a shield of gas around arc/puddle to protect it from oxygen till it solidifies...
TIG is Tungsten Inert Gas welding and is sort of above what you need to know at beginners level, but its using a tungsten rod and a shield gas (usually argon) to create a arc/puddle at the joining of two pieces of material to be bonded and unlike SMAW or MIG the welder has to manually feed filler rod into fusion bond.... Very similar concept to oxy/acet welding but using a electrical arc instead of a fuel (gas) and oxygen...
Might want to invest in something like this to help you understand what it's all about, mugh get it online or drop buy local public library to see if the have some books on welding...
Dale
SMAW is shielded metal arc welding.
Ron
/ Welder question... #43
Yikes... you are touting a $3000+ system to a newbie welder. My suggestion is that someone diving in for the first time should be looking at something like a 110v/220v MIG... or a cheaper stick if he is brave and patient. OP needs to learn not only to weld but also whether at some point, decide if he wants to dive in deep. Most of us hacks can get away easily with a stick or MIG machine with far less capability/complexity than yours. Very cool welder and you are a lucky man to have! If you are in the trade and you need to travel to use for various weld projects, I get it.
It seems that at that price, multiple machines as you increase your skills might be a much better avenue and you don't have to jump in deep. I am contemplating a TIG myself. Do I need it... NO. But sure would be nice and I could spring for it and after paying for that, plus my Miller 211 MIG, I am still quite a bit less out of pocket than a multi process machine such as the 255.
Did you read my entire post? I also pointed out a guy can buy an entry level buzz box for $150.00. I知 not promoting any particular welder just giving a new guy a range of costs and capabilities. Generally speaking you are not going to weld less than 1/8 thick with a stick welder. What you buy really depends on what you want to weld.
/ Welder question... #44
Most of these acronyms don't mean anything to me... (just disclosing how little I know about this)
Anyway.... Any welding would be done outdoors, nothing inside. My garage needs some wiring done (some extra outlets and more lights) I ALREADY have some (if I recall correctly) 8g 3 wire (??) that was used to carry power to a second panel box.
So, I can make a dedicated 220V (and or) 110V outlet for any purpose.... I have a clean drawing board and already have the wires, just need breakers and outlets.
May I presume that if I can weld something using 220 volts, I can ALSO dial it down and do something that (was described above) as sheet metal, where the 110V unit would work.
Let me re-word that....
I can weld with 110V and do so much....can't do "heavy" welding that might require 220V.
HOWEVER, if you use a 220V system, you can do the heavy stuff AND you can also dial it down for the 110V stuff?
I am one that prefers to buy something nice verses go the least cost route. No disrespect intended, but I try to avoid Harbor Freight if at all possible.... My primary wrenches/sockets are Snapon with backups of the Craftsman, MAC and Cornwell (?) type.... Had too many cheap tools snap when needed decades ago so just pay the piper and avoid them.
Never thought about used.... going to poke around Craigslist...
My :2cents: again,
I would suggest you go to your local welding gas companies and look at the desired welder with their help, and maybe they might have a good used one that someone traded in...
Good luck, KC
/ Welder question... #45
I have done certified level work up to 1/2" with an AC buzz box. Do not under sell them. Even a lot of the lower end ones in the 200 Amp/240 Volt size do decent work from a decent level welder. Lower the amperage the harder to do heavier thickness work.
Ron
/ Welder question... #48
I've read that's what they used in WWII shipyards to build the 400+ ft Liberty ships.
All of the WW II surplus welding machines I in my younger days were GE and Westinghouse 400A MG sets. The surplus market had them for real cheap. Lot of them out there still running strong.
Ron
/ Welder question... #49
Yes I did... no offense. I think though for a starting out homeowner the sweet spot if he (or she) can afford it is a name brand 110/220v MIG. This is in the $1000 range. I think this allows you to get up to speed faster making it more enjoyable and a 220v machine is plenty capable for most anything a homeowner would/should tackle and can be dialed back to do some delicate work until you get the itch for TIG (where I am at :licking:). If you find you don't enjoy welding or just don't have that many projects or excuses to use your welder, you aren't out too much and you will recoup most of your investment as many are looking for clean used machines at a discount off of new.
/ Welder question... #50
We have a Everlast PowerArc 200STi and have been very happy with it. It works on both 120V/240V and you can adjust the output amps from 1 amp up to 200 amps.
They also make a line of MIG welders that are reputed to be good.
Our neighbor has a Miller Multimatic 200 MIG welder and that is nice, you set the thickness of your metal on the dial and it automatically sets everything else.
I really like the ability to work on both 120V and 240V power, mainly because it's a lot more portable that way.
Aaron Z
/ Welder question... #51
I purchased a Hobart Handler 190 a few years ago. Its a 190 amp 230V unit. The Handler 190 kit comes with a gas regulator to hook up a tank, or you can use flux core wire if you wish. It also comes with a spoolgun for doing aluminum or stainless if you ever wanted to. Mine is set up with a tank of 75/25 for normal steel. For doing much aluminum or stainless though, you would want to get the appropriate gas for them. I run Hobart or Lincoln wire in it, and it welds everything I have ever needed to do, from thin stuff up to 3/8" or so. (I've never needed to weld anything thicker yet.) The whole setup comes in ~$700-$800 new, less if you can find a used one. It seemed like a lot of bang for the buck; I wanted a 230V gas-ready MIG welder from a brand name company that I had heard good things about. The 480v Miller MIG and TIG units we use at my work are awesome, but those are big $ units that would be overkill for my garage use a few times a year. I think you'd be basically safe with any Miller/Lincoln/Hobart product, and I'd definitely suggest getting a 230V unit over a 120V unit if you can swing it. The 230V unit will do anything a 120V MIG will do, and have more power available for use on thicker stuff if needed.
/ Welder question... #52
If you can stretch for a dual voltage mig, that would be my recommendation. You'll be able to use it for small jobs outside of the garage. If Looking for a dedicated unit for the garage go with 220v.
/ Welder question... #53
I had similar needs for a welder quite a few years ago. Occasional use around the property on a variety of thicknesses of steel. I shopped the used market for a portable welder, ended up with a Lincoln 200 amp which has done everything I needed and provides backup power when needed. I have welded 1/16 to 5/8 material and ran my plasma cutter with it. It doesn稚 have Mig or Tig which is just fine for me as I can do all I need with stick. Keep it simple and cost effective for the intended use.
/ Welder question... #54
My first welder was a converted stepdown transformer that I re wound to desired output voltage.
My then problem was current control so I used different rods.
Burn thru was a frequent problem but things stuck together.
Today I use a nice Hobart but always a stick fan.
Never took any courses and it is very rare that I need to repair a weld.
My tractor cab is DIY as is my front snow plow.
Choice size and quality of rods is one secret as some forgive more than others.
Heck, just for the fun of it, I recuperated a big shop battery charger and made it into a light duty AC stick welder.
Next project is a light duty spot welder using a microwave transformer, should be fun.
And I never leave an old steel bed frame out for pick up, do carry tools to dismantle on site.
(Bedframe angle is just great for making power tool bases.)
/ Welder question... #55
Spoke with local trade school one day. I don't recall exactly what I was told but my memory is I could take a class and learn there......but, I'd first have to sign a waiver form that I'm learning to learn and NOT for a job afterwards (they don't want to damage their placement percentages which I fully understand) AND, the class would cost right around $5,000.
WOW! I took an evening welding class taught by the high school shop teacher 15 or so years ago. It cost couple hundred $. It was very basic: 6 weeks of meeting one night a week for 2 hours a night.
I also took an evening Adult Education class at the local career center/vocational school. $500 for 6 weeks, two evenings a week, 2.5 hours per session (30 hours instruction, total). I just checked, they are up to $600 now. Their first class is mainly stick welding, with a very brief into to MIG at the end. The intermediate class deals mainly with MIG / TIG - similar hours & similar costs. They cost includes supplies used during the class. I thought these were a very good deal, and a good way to jump start my welding. I took the first one 5 or 6 years ago. Would like to get in to the second one, but have not been able to fit it in to my schedule.
It sounds as though the class your trade school is talking about is to become a certified welder. I doubt you need that.
/ Welder question... #56
This is my welder. Everlast PA160. It cost me $265 bought thru Mark here on this forum. It is a stick welder. It was the second machine I have owned. My first was a Lincoln 225 AC only so called "buzzbox". They are called buzzboxes because they buzz when you weld with them. They do OK, but the quality of my welds improved 100 percent when I went to a DC machine like my little Everlast. It weighs about 20 pounds or so. The Lincoln buzzbox weighs well over a hundred. My trusty buzzbox got sold as soon as I made a few welds with the little inverter DC machine.
Below is an example of the kind of welds it can make with some 7018 rod. Yes stick welding takes longer to learn. I taught my self totally. No one around to help me or show me anything. My first welds were NOT very good. But I did put the AC machine to work pretty quick gluing my old mower back together many times. The mower was totally outmatched to the job I was asking of it. Rough ground and lots of it.
Stick vs. Mig (and its cousin flux core) . yeah, kinda like the perpetual arguments about .45acp vs. 9x19. AG vs R4, Chevy vs. Ford. And on and on. There is room in the world for both processes.
Which is cheaper to buy? Stick (except for a few Harbor freight things) . Which is cheaper to operate? Stick. Which is quicker to set up? Stick. Which has less mechanical complexity? Stick. Which will give good penetration EVEN in novice hands every time? Stick.
Which is harder to learn on? Stick. Not many people will argue these truisms. Although you could write a book about the advantages and disadvantages of each process, and many such books have been written. Welding is not a simple subject, and many men and not just a few women have spent a lifetime perfecting their skills on the various processes. It can't always be boiled down to a "which is best" and "what should I buy/" type of question. It is complicated. Like most things in life.
Good luck on your welding journey.
/ Welder question... #57
Stick welding is the cheapest for welding plate. And there are always used Lincolns on craigslist for a little over $100 all the time. You just don't use stick for sheet metal. A stick welder 220v is going to weld 1/4 inch plate better than any MIG 110v and will be cheaper to buy.
Don't worry about 7018 rods as you need to store those rods in a rod oven. You can not leave 7018 rods out in the air. If you are running an AC stick welder you need to buy AC rods. There are AC and DC rods. You need to match your welder.
/ Welder question... #58
My 1st welder was the Lincoln 230 AMP "Buzzbox" that I used for 30+ yrs. then I bought a H.F. Mig unit for light work. Lincoln makes the tombstone in both AC & AC/DC models, last I looked the AC/DC was +- $500 while the AC was +- 300. I found a used AC/DC for $250 on C.L. and grabbed it up. I got $250 for the old AC unit. I used the Lincoln for heavier stuff and thought of the H.F. as a glue gun which was very useful for light work.
I have since lost the vision in my right eye which resulted in the loss of depth perception so no more stick welding,I still use the little H.F glue gun to stick stuff together and get by.
/ Welder question... #59
I've used the heck out of a HFT 90A flux welder, not a great welder but if treated reasonably (IE never running .030" wire, always .035 and using the wire speed to fine tune the heat and change speeds accordingly...) it could surprise you. I think it is too hot for .030" wire, high or low doesn't matter .030 just flat doesn't work... I've tried name brand and cheapie wire and it's more based on wire size... My Titanium 200 and 175 welders on 110V or 220V following the suggestions on the lid is a whole different story, they weld great with flux core... I abuse the heck out of the 175 since I got it for $125 on an open box sidewalk sale thing...
If you can, go name brand though like said which sounds like you are going to anyway, but flux core is easy, messy but cheap and forgiving... it's like stick welding but more in a glue gun...
/ Welder question... #60
Those 7018 rods I welded that hook on my Kioti have never seen the inside of a rod oven. Yes, they are stored in a gasketed plastic rod holder in the basement. Not a rod oven by any means. And they seem to weld pretty good to me. I am not going to leave them out in the rain, but for the kind of welding we do around the place, the plastic rod holder seems to be just fine.
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
JOHN DEERE 4450 TRACTOR (A63290)
JOHN DEERE 4450...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
HUTCHINSON 24" DRAG CHAIN GRAIN ELEVATOR (A63290)
HUTCHINSON 24"...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
