whats this for
- Joined
- Sep 3, 2019
- Messages
- 6
- Tractor
- Ford 4000 Industrial & Ford 1910
Hi,
I'm new to TBN, and I'm a fairly new tractor owner. Actually, I currently have 2 tractors:
1964 Ford 4000 Industrial
1986 Ford 1910
I'm writing about the 4000. I bought it in July, when I knew even less than I do now. It was a mistake for a few reasons, leading me to buy the 1910 recently. I will be selling the 4000, but a few things need repair before I do that -- radiator, alternator, and oil leak. I'm writing hoping for help regarding the alternator.
The specific problem is that the pulley on the alternator broke.
I have an idea why it may have happened, but I could be wrong of course. The oil leak I mentioned above is somewhere on the front of the engine. The previous owner said it was minimal enough that he would just add a few ounces every 10 hours or so. I'm wondering if that leak led to oil splattering on the belt, which led to the belt slipping, which then led him to tighten the belt too far, and that was enough pressure to weaken, and eventually break, the pulley. (It broke a few months after I bought the tractor.) If that all makes sense, then I would want to fix that oil leak so I'm not passing the same problem on to the next guy.
Specifically regarding the alternator, it would be nice if I could use the same one, and just replace the pulley (and perhaps the fan that sits between the pulley and the alternator body). However, I am not having much success with that.
Originally, the 4000 had:
- generator & voltage regulator
- 6-volt system
- positive ground
The previous owner replaced the generator with an alternator. (The voltage regulator is still present, but not used.) It is still 6-volt with positive ground.
I figured that replacing the pulley would be easy. I brought the alternator and pulley to NAPA. Not so easy. He was not able to determine the brand/model of the alternator, although he did point out the following stamped into the back end of the shaft:
USA
INA
BCH 06604
The pulley itself doesn't seem to have any markings on it.
He spent probably 20 minutes searching online for information, but found nothing. And apparently he didn't simply have a number of pulleys in back that we could try to eyeball it. I got the impression from him that it is important to get the exact right pulley. I guess I thought it would be as simple as looking at V-belt-type pulleys that have the specific shaft hole diameter, and approximately the same outer diameter. But he said it is more complicated than that. Do you agree?
Another note on the pulley -- both it and the fan have a slot for a square key, but the alternator shaft does not. A friend pointed out a hint of yellow paint on the pulley, and suggested the idea that perhaps the pulley and fan are not the ones that came with the alternator, but instead are the ones from the original generator. Another note -- there is no set-screw to secure the pulley to the shaft. So the only thing that keeps the pulley from slipping on the shaft is the main nut. Is that normal? Or is that more likely the result of taking the pulley from the original generator and (inappropriately) using it on the new alternator? Should I be looking for a pulley that includes a set-screw? If I were to find the correct pulley, would it include a fan -- perhaps factory-attached to the pulley?
If I (with your input) am able to find a pulley (and fan?) that will work, then great. Otherwise, I would need to consider replacing the alternator, and would value any help you have in how to select the right one.
Thanks for your time!
1986 Ford 1910
- 6-volt system
- positive ground
USA
INA
BCH 06604
